Red Oil Light Flash on Shutdown - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-13-2012, 03:40 PM   #1
Weste46
My Ride: 2001 330ci
I've had this happen every once in a while, its a simple, quick flash, right on shutdown. I looked it up, and found one thread on it. The thread happened to be made by the previous owner of my vehicle..
Sent from my DROID RAZR MAXX
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, 95a FCA, 75d rear subframe, 95a RTA, 95a RCA, 88a diff., 75a swaybar mounts, ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, intake, headers, x-pipe, open-loop EU2 tune, ~180lbs weight reduction.
Weste46 is offline   Reply With Quote
Old 11-13-2012, 03:57 PM   #2
FenderGuy05
My Ride: 2002 BMW 325i
Is it red or orange? I've had an orange flash, meaning oil is at or below minimum level. Red would indicate that there's a loss in oil pressure I believe, but on shutdown I'm not sure if it has another meaning.
FenderGuy05 is offline   Reply With Quote
Old 11-13-2012, 04:07 PM   #3
scarede46er
My Ride: 2001 BMW 325i ZSP
Your oil pressure sensor is going bad. Repair ASAP.
Sponsored Links
Advertisement
Old 11-13-2012, 04:35 PM   #4
trizzuth
My Ride: Best M5 ever made
Nah, this never happened to me and is not a sign of the sensor going bad I believe.
Direct indication of the sensor going bad is that it comes on in orange immediately after start up, even though the oil level is good, stays on for about 20 seconds and then goes off. This will happen each and every time you turn the car off and start it again, and that is the indication that the sensor is bad. Never heard or read anything about it being red and indicating the same thing..
2003 BMW E39 M5 - Current!
2001 BMW 330i - Totaled at 236K :(
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is offline   Reply With Quote
Old 11-13-2012, 04:36 PM   #5
scarede46er
Trizuth: That is the oil level sensor. There is a separate oil pressure sensor.
Old 11-13-2012, 05:09 PM   #6
Zell
Zell's Avatar
My Ride: so turbo wow
Oil level and oil pressure share the same light. Red is for pressure, amber is for level. Oil pressure takes priority over oil level if both are giving signals at the exact same time. This sounds like an oil pressure sensor problem.
Old 11-13-2012, 06:26 PM   #7
Lusticles
My Ride: 325Ci
When my sensor went bad it started doing that. Then as time went on it would rapidly ignite on and off for a few seconds every now and then.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 11-13-2012, 07:45 PM   #8
scarede46er
Yes, Zell. Thank you, but I am aware of that. However, the light is fed via two different sensors. One is the thermal oil level sensor. While the other is the oil pressure sensor. The part number for the pressure switch is 12611710509 or 126175688480. The part number for the level sensor is 12617508003. OP needs the former.
Old 11-13-2012, 08:05 PM   #9
trizzuth
Ahh, that is what I get for reading to fast.. Thanks for that, where does this oil pressure sensor live?
Old 11-13-2012, 08:06 PM   #10
Weste46
My Ride: 2001 330ci
Okay great, so its not a mystery like all my other problems are. XD is this a threat to my engine, or can I get around to it this winter?
Old 11-13-2012, 08:13 PM   #11
Weste46
My Ride: 2001 330ci
Also, it seems like he went after it and failed to fix the issue.. I also have the same traction control light turn on with shutdown occasionally, just like the PO said in his thread. Here is is: http://forums.bimmerforums.com/forum....php?t=1648854
I also have a limp mode issue right now that has gotten progressively worse since receiving the vehicle. Possible relations?
Old 11-13-2012, 08:16 PM   #12
scarede46er
The presence or absence of the sensor itself is not critical to your engine. Assuming you aren't leaking or burning oil, you will not even notice the sensor. However, IF the pressure DOES drop, you will get no warning whatsoever. Bye bye engine. So yes, in theory, you do not NEED to fix the sensor. But you need to fix it asap. It is a 30 min diy, or that's how it seems. And it's dirt cheap, especially as compared to other BMW parts. Use furiousmethod.com to get the best price for the OEM part only. I think it is located somewhere near your VANOS. I am not sure.
Old 11-13-2012, 08:17 PM   #13
Weste46
My Ride: 2001 330ci
Also, I found the leak he never did. It doesn't hit the ground, and leaks about 1 quart every 2k miles, from the area around the exhaust side cam position sensor, but I replaced the cam sensor o-ring and it did not stop the leak. The VCG was done by him as well.. so not that. Is there a relationship there??
Old 11-13-2012, 08:23 PM   #14
scarede46er
The oil pressure switch should not cause a limp mode if it goes bad. Have you had the codes read? I suggest you invest in a BMW Scanner 1.4 from ebay. 30 bucks well spent.
Old 11-13-2012, 08:24 PM   #15
scarede46er
I think there is a huge thread on the forum about oil leaks. I suggest you read that. It is one of the most comprehensive guides ever. Has the oil filter housing gasket ever been changed?
Old 11-13-2012, 08:27 PM   #16
Weste46
My Ride: 2001 330ci
My limp mode issue is being addressed, that's here: http://forum.e46fanatics.com/showthread.php?t=951425
Any help would be wonderful on that!
The oil filter housing gasket is fine for now, but I don't believe it's been done. I checked it though, it's fine for right now.
