Thermostat/housing dismantling - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-13-2012, 05:38 PM   #1
Barneyhyphen
My Ride: 2004 M3 Convertible
So, in the olden days, we used to take the thermostat out of the Morris Oxford, Ausin A35, put ut in a saucepan of water and heat it up on the stove. Just south of boiling, it should start to open.
So, here we are with an E46 thermostat housing/thermostat/sensor, we disengage the actual thermostat, (most likely the first error) from the plastic housing and drop it in the saucepan.........didn't open BUT, due to the way it works, it probably wont open BECAUSE I now think it dependent upon the thermostat body/cage being held by the plastic housing.
Now, we attempt to refit the thermostat, back on to the long SS bar/pin BUT, it will only go back on the bar/pin about 1.50" (1.00" less than it needs to).
I believe I may have allowed the wax inside it to run where it doesn't belong and said wax is now preventing me from reinserting?
Any thoughts please, thanks.
BH
Barneyhyphen is offline   Reply With Quote
Old 11-13-2012, 06:51 PM   #2
Barneyhyphen
"problem" resolved.......reheated the thermostat and managed to re-fit it back in to the housing.
As a matter of interest, how far does the thermostat actually open, when fully open? 3/8" space between the sealing disk and the seat against which it seals?
Thanks.
BH
Old 11-13-2012, 07:01 PM   #3
Ballistic325
My Ride: slow and steady
So, you are trying to repair the thermostat?
Interesting, sub'd for progress and results.
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-13-2012, 07:10 PM   #4
jgold47
My Ride: 2004 X5 3.0
Ours are an integrated unit with the stat and housing. I would just replace the whole thing. Not too expensive.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
