Old 11-13-2012, 05:30 PM   #1
Rabih Fares
My Ride: E46 325i - E36 325i
Wet floor
I've found the floor wet in my e46 325i 2001,LHD,in fact the carpet in front the passenger seat is so humid...
Any info plz
Rabih Fares is offline   Reply With Quote
Old 11-13-2012, 05:48 PM   #2
Stinger9
My Ride: '04 330Ci
door vapor barrier
had any work done on doors lately?
Could be other things. Any windshield work lately?
Think about any other work lately that could affect things here?
Old 11-13-2012, 06:16 PM   #3
Rabih Fares
No not really,but I just noticed the windshield's frame is not looking normal,so i'll check it,thx anw and i'll feed u with the results.
Old 11-13-2012, 06:17 PM   #4
BDUB328I
My Ride: bmw 328i S54 sedan (
it could also be the drains are cloged often times the sunroof drain. check them and get all the debris out
BDUB328I is offline   Reply With Quote
Old 11-13-2012, 06:25 PM   #5
Rabih Fares
In fact it doesn't contain a sunroof,but what is that door vapor barrier,is it the gray underlay attached (glued) to the side door?
Old 11-13-2012, 06:26 PM   #6
DangerousMind
My Ride: Sierra 1500 SLT
Check if it is coolant by pressing a paper towel onto it and seeing if it is colored, or rub it and smell your finger. If it is coolant, it is the heater core or heater core valve.
If it is just water, it is most likely the sunroof cassette drain tubes. If you don't have a sunroof, then could be the windshield seal or that the air conditioning cowl drain is clogged.
http://www.e46fanatics.com/forum/sho...d.php?t=912538
http://www.bmpdesign.com/technical/e..._seal_leak.php
DangerousMind is offline   Reply With Quote
Old 11-13-2012, 06:37 PM   #7
Rabih Fares
I think it isn't cooling,cz I guess water is coming from the bottom
Old 11-14-2012, 06:06 PM   #8
BDUB328I
yes its the grey part inside the door that is glued
