Old 11-13-2012, 11:35 AM   #1
timmy5192
My Ride: 04 BMW 325i
Locked out from my 325
I have an 04 325i and the remote to unlock/lock car had died many months ago. Just yesterday the manual lock on my drivers door just broke, and it broke on lock. So I now have no way of getting in the car. I was thinking about buying a new lock kit of ebay and buy a slim jim to break in. Any opinions or advice would be appreciated. At the moment im just trying to get access to my car.
timmy5192 is offline   Reply With Quote
Old 11-13-2012, 11:37 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you look over this link -
http://forum.e46fanatics.com/showpos...5&postcount=22
Old 11-13-2012, 11:37 AM   #3
agillzz
My Ride: 325ci
Go in through the passenger side. Boom.
agillzz is offline   Reply With Quote
Old 11-13-2012, 11:46 AM   #4
HiHoBrian
My Ride: 05 M3
:screwy: You don't have an e46 do you...there is no lock cylinder on the passenger side.
Op, can you open the trunk,and either fold down the seats to get to the central lock button?
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 11-13-2012, 11:49 AM   #5
agillzz
My Ride: 325ci
I have a 2004 325ci, just didn't know there wasn't a lock cylinder on the passenger side. But honestly that was a joke, sorry haha
Old 11-13-2012, 12:07 PM   #6
jfoj
Just going to repeat myself!!!
Suggest ANYONE who has a E46, E38, E39 to read the link.
You should have more than 1 working keyfob AND know for sure your driver door linkage is working.
Many of the German/European Central locking systems are great while they work and you have a key, but once you loose your key and/or the central locking does not work, you may be SOL!
Old 11-13-2012, 12:21 PM   #7
E46Moonlight
My Ride: 2000 323i
Break the window, it's cheaper to replace the glass if you realllly need to get into your car
E46Moonlight is offline   Reply With Quote
Old 11-13-2012, 09:10 PM   #8
dznuts007
My Ride: 2001 325i Sedan
I had this happen to me once while I was 60 miles away from home. Called 3 tow trucks and none of them could successfully jimmy the car open (they said BMW's are too tough to get into if you don't have the key) I guess this is good news regarding the security of the car and decreases the chances of getting it stolen, but I was SOL.
I ended up having to break a window to get inside. The next day when I went to get my window replaced the guy told me that it was good that I broke the passenger window instead of the passenger small corner window because he said those are more expensive to replace than the passenger window.
dznuts007 is offline   Reply With Quote
Old 11-13-2012, 09:20 PM   #9
jfoj
The trick is you have to push the center console lock button with something before you try to pull the door handle to get the door open.
That's assuming the center console lock button is not broken!
Old 11-14-2012, 05:34 PM   #10
timmy5192
and I have the model with the metal wall in between my trunk and my back seat
Old 11-14-2012, 05:35 PM   #11
timmy5192
i can et the door cracked a little bit with a towel and a flat head so im gonna try and get a wire in there or something. and just curious how much does a passenger side window cost
Old 11-14-2012, 05:39 PM   #12
jfoj
You need to get something long to push the center console lock button, then pull the door handle 2 times as I recall.
Good luck.
Old 11-14-2012, 05:52 PM   #13
sea6speed
My Ride: 2010 335i Msport 6MT
How did you not see this coming?
sea6speed is offline   Reply With Quote
