Old 10-22-2012, 02:48 PM   #1
evo7
My Ride: 2003 330i
Replacing only the pulley, not tensioner?
I have a 2001 330ci. The A/C tensioner is mechanical, the waterpump tensioner is hydraulic. Is it ok to replace only the pulley on the tensioners?
The whole A/C tensioner is $43. The pulley only is $20
I can't find waterpump hydraulic tensioner anywhere, but the I found the pulley only for $30.
evo7 is offline   Reply With Quote
Old 10-22-2012, 02:52 PM   #2
My Ride: M54B30
See sig with professional links. Do it all.
Yes you can do pulleys separate. The pulley you need is branded Dayco. Check my link
Amazon.com - Dayco 89133 Pulley
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 10-22-2012, 03:00 PM   #3
evo7
My Ride: 2003 330i
Is the same pulley can be used for both the A/C and main tensioner? My main tensioner is hydraulic, does that make a difference?
Old 10-22-2012, 03:00 PM   #4
Zell
Wears carbon fiber boxers
Zell's Avatar
My Ride: 330Ci ZHP 6sp
Yep. That's what most people do.
E46Fanatic's resident mathemagician
Old 10-22-2012, 03:24 PM   #5
My Ride: M54B30
Your a/c will be dayco. the other tensioner will be OEM from any vendor site.
Old 10-22-2012, 03:24 PM   #6
My Ride: M54B30
i need to do a thread on pulleys, don't i
Old 10-22-2012, 03:35 PM   #7
evo7
My Ride: 2003 330i
Thanks. I just read your thread, and DMAX mentioned the Dayco 89046 for the main tensioner pulley. On pelicanparts.com, it listed this INA pulley. Are they both the same?
Also, correct me if I'm wrong. To remove the tension or to replace the pulley on the main tensioner, I need a T50. Is that the same for the A/C pulley? Im running to the parts store in a bit to grab a T50.
Old 10-22-2012, 03:38 PM   #8
My Ride: M54B30
Yeah. Just go w/ INA. order it w/ the rest of your cooling parts. Either is fine though.
Old 10-22-2012, 03:42 PM   #9
BMWCaptain
My Ride: 03 325iT Sport Wagon
The pulleys have been what goes bad most of the time. I have yet to see anyone who has a spring tensioner go bad.
It is a lot cheaper to just replace the pulley for $19, than the whole pulley at $50+.
BMWCaptain is offline   Reply With Quote
Old 10-22-2012, 03:54 PM   #10
My Ride: M54B30
I have. Lots of them. I'll post some pictures soon of some broken ones. It's good PM and one of the few things I still need to do!
Old 10-22-2012, 05:25 PM   #11
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.04646 mu
Replace the idler pulley too. If one is bad, they all will be soon.
Autozone has Dayco pulleys, as said, they're OEM...INA.
Mechanical and hydraulic tensioners do take different pulleys...doesn't matter if they're on the AC or ACC belts. If tensioner is different, the pulley will be.
T-50 is it for many pulleys, but some have a different bolt (hex head), and who knows, you're might be something completely different installed by someone at some point. You have to look and feel. A number here have stripped bolt heads, undoubtedly because they didn't look or test.
Easy repair. Don't forget to either get new belts or put your old ones back on in the same direction they're in now.
Old 10-22-2012, 07:11 PM   #12
evo7
My Ride: 2003 330i
Thanks alot guys. It stopped raining so I was able to go outside and take a look. The adjusting pulley is a torx bolt, which is a T50 I assume. The a/c side is a hex bolt. Any ideas what size is that hex bolt?
Old 10-22-2012, 07:24 PM   #13
BMWCaptain
Probably 16mm. I use 16mm to pull back the pulleys when changing the belt.
Old 10-22-2012, 07:44 PM   #14
Alex323Ci
My Ride: M3 & 323Ci (sold)
funny because after working on bmws for decades i can usually just go in my garage and look at some parts. so i just did. if you're talking about the mechanical tensioner bolt that holds the pulley on it's also a T50 torx. but bmw may have changed it over the years if yours is a Hex head.
OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK
CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF
Old 11-14-2012, 04:43 PM   #15
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
after reading all these threads, i was still kind of lost... but i did mine over the weekend and the hydraulic tensioner pulley is indeed a hex bolt, but ive been using a T50 to loosen it for quite some time now and it works.
parts needed:
hydraulic tension pulley - dayco 89046
ac pulley- dayco 89133
idle pulley - 89089
* some might get confused on which pulley is for the mech ac and hydraulic tensioner, because i certainly did.
this pulley is for the hydraulic tensioner and used the hex bolt. so naturally, the othe pulley is for the mechanical ac and used the torx bolt.
Devious1 is offline   Reply With Quote
Old 11-14-2012, 04:55 PM   #16
328iguy24
My Ride: e46 328i
While your at it you might as well just replace the tensioner and water pump along with belts imo.
328iguy24 is offline   Reply With Quote
