Old 11-14-2012, 10:09 AM   #1
Poncho@home
My Ride: MY04 330Cic ZSP
Key FOB Battery question
The key FOB gets recharged while in the ignition.
Now that my car is in storage for the winter months, I have installed a trickle charger to keep the car battery charged during storage. Should I leave the key in the ignition to keep the FOB charged as well or is it no big deal to leave it out and risk the battery losing its charge.
I only have the 1 FOB, no spares.
Any thoughts?
Poncho@home is offline   Reply With Quote
Old 11-14-2012, 11:29 AM   #2
jM2.me
My Ride: BMW
Subbed. Had car stored for a while and never thought of this.
jM2.me is offline   Reply With Quote
Old 11-14-2012, 01:10 PM   #3
jgold47
My Ride: 2004 X5 3.0
These are pretty long life button batteries. I would think you would be able to get several months of standby if not more. I think people go yeas without using their extra key and I they work fine.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 11-14-2012, 01:22 PM   #4
jM2.me
My Ride: BMW
Doesn't coil, on the ignition, power and then charges the key even if it was dead in first place?
Old 11-14-2012, 01:33 PM   #5
lcoleman
My Ride: '79 Massey Ferguson
I am 90% sure the fob uses a lithium battery...in which case, it would be better to leave it out. The self-discharge rate is low enough to last the winter months, and keeping a lithium battery at 100% SOC only reduces capacity and cycle life.
Old 11-28-2012, 02:04 PM   #6
Poncho@home
Thanks for the response Icoleman.
Old 11-28-2012, 02:22 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
If you only have 1 keyfob, you better buy another one, $160 USD in the US.
Also make sure you driver door lock linkage is not broken!!!
BIG MISTAKE owning an E46 and only 1 key.
Key will not charge if car is not running, so do not bother to leave it in the ignition.
Old 11-28-2012, 02:28 PM   #8
Poncho@home
Yeah, I do plan on buying another key FOB and my door lock linkage works just fine, I tested it.
When I purchased the car it came with the 1 key only.
What are my other options? Can I purchase a non FOB key instead, again my door lock linkage works fine & will the linkage break if I don't use it?
Old 11-28-2012, 03:23 PM   #9
jfoj
Other options are a plastic wallet key & replacement key, opens all doors, trunk glovebox and starts car. Usually $60 USD.
Do not bother with a Valet key, stupidest thing to buy from the parts department, but they ALWAYS recommend a Valet key first. Will not open trunk or glovebox. Kind of useless when you lock your only key in the trunk and you have the car in Valet mode!
Still smart to have a 2nd working keyfob, just search about all the people locked out of their car when the driver door lock linkage is broken.
You never know if someone tried to break into your car and your drivers door linkage is broken. Again the drivers door linkage is made to break if forced.
You would be better off with a cheap used keyfob that does not work to open or start the car but will unlock the car wirelessly, only issue is how to keep the other keyfob battery charged.
Old 12-16-2012, 12:59 PM   #10
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
i have the lock delete cover on drivers door
sooooo, basically, if the linkage broke , would there be any other way into car? key will open all doors and trunk so, y would one key fob be an issue?
i have only one key fob
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
