E46 Xi Forum
Old 11-14-2012, 11:13 AM   #1
devin_name
My Ride: 2004 325i
Front drive shaft help
Hey guys, hoping you can help me out. I am replacing the front drive shaft on an '01 325xi. The Bentley manual is zero help on this matter BTW. Anyway, I can not get any of the bolts to break free from the front flange. It's a pretty tight space to work in and I don't think an impact wrench would even fit in there. I sprayed it with penetrating oil last night and let it sit hoping it would be easier today. Any tips on how to get to these and get them out?
Also... I don't think the bolts are actually seized... just a fairly high torque and tight spot to get to makes for very difficult time removing.
devin_name is offline   Reply With Quote
Old 11-14-2012, 11:25 AM   #2
SamDoe1
My Ride: 4cyl of fury
Breaker bar or a cheater bar (aka a pipe).
Aren't the driveshaft bolts an external torx head? If so, I hope you're using the right socket.
Also, spray it again with the penetrating oil.
Old 11-14-2012, 11:32 AM   #3
Kubica
My Ride: 2003 325xi
No I don't believe they are torx head. Use a one foot extension and a breaker bar. A little bit of heat is ok, but don't burn the input seal of the diff.
Use loctite on the bolts (especially at the rear of the driveshaft).
Old 11-14-2012, 11:39 PM   #4
devin_name
My Ride: 2004 325i
Actually they came out no problem when i tried them today after letting then sit with the penetrating oil for 24 hours. I really apreciate the help though guys. Especially on using loctite. I bought some just in case but almost didn't use it sonce Bentley didn't say to. Godd to hear I was on the right track.
Sent from my SCH-R760 using Bimmer App
