Old 11-14-2012, 05:32 PM   #1
dell84
My Ride: 2004 330i ZHP
What kind of lighting is this in my headlight?! And problems..
I know I can always count on the community here to give me some good answers. My driver side headlight seems to be intermittently going out now a days. I looked at one of the female connectors connecting to the bulb -- the wire seems frayed so I'm guessing thats the cause of that? Also, I ordered khoalty angel eyes but I'm not thinking whether I should even put them in because I don't know if it looks classy (bordering on ricey?). Also, when I tried to put them in, I noticed the angel eyes I do have are already built into the light so they light up behind the khoalty ones which doesn' t look good (I bought this second hand so I have no idea what kind of angel eyes these are, but it seems to be built in). Also, some of the led angel eyes I have are kind of fused. Also, the khoalty angel eyes are hitting the bezel and aren't an ideal fit (some of the bezel ultimately covers up a portion of the angel eye). THUS, I'm thinking of returning the khoalty angel eyes, which leads me to..
  • What kind of headlight is this? (xenon, bi xenon, projection, etc)
    Am I right in assuming putting any new female connector will work fine to fix the light issue? The autozone rep mentioned that these might be HID lights thus requiring special wires/connectors.
    What kind of angel eyes are those currently in there? It appears to be little bulbs, some of which are out. I'm thinking I can just replace the bulbs? Or maybe its the wiring? I don't know! Is it easy to open up the light to replace the bulbs? You can see in the pictures the little lights circulating around the headlight, 2 of them are out. Its like that on both sides.
ID:	478183   Click image for larger version
ID:	478184   Click image for larger version
ID:	478185   Click image for larger version
dell84 is offline   Reply With Quote
Old 11-14-2012, 06:44 PM   #2
haurelio
My Ride: 2001 bmw 325i
it looks like a Depo Headlight (p46)
Contact me if you need to unlock your phone.
Also can code your car
Old 11-14-2012, 11:24 PM   #3
dell84
thanks! after doing some google image searches you seem to be correct. anyone got answers on my other questions or any advice?
Old 11-14-2012, 11:30 PM   #4
montchobadmoves
My Ride: BMW 335i 2007
Regarding your connector, it might be easier to splice the wire. So you keep the original connector.
montchobadmoves is offline   Reply With Quote
Old 11-14-2012, 11:32 PM   #5
montchobadmoves
Forfet about splicing the wire, I just look at the picture, for sure you have to replace the connector. Any one will work fine.
Old 11-14-2012, 11:34 PM   #6
dell84
thanks a lot!
Old 11-15-2012, 08:09 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Those are not even Depo headlights, those are extremely extremely cheap ebay headlights. I suggest you just save up, get OEM halogen lights and retrofit in Morimoto mini projectors.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 11-15-2012, 02:54 PM   #8
dell84
Are you sure? I sent khoalty these pictures and they said that the Depo would fit in these. Also, the headlight had a yellow sticker label on it that had the company info (a cheapo ebay wouldn't have that right) and "SAE" and a little UPC.
Old 11-15-2012, 03:40 PM   #9
dell84
Also, can I put HID bulbs in my headlight? Or does that require a whole modification of the headlight assembly? Reason why I'm asking is because I don't want the yellow of my H7 bulb to clash with the white of the AEs.
Old 11-15-2012, 04:02 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
They are cheap, period.
Old 11-15-2012, 07:34 PM   #11
haurelio
tomatoes tomatos.. same thing
Old 11-16-2012, 01:12 PM   #12
dell84
thanks for the input, even the cheeky comments.
I got a new female connector for the headlight and that fixed the light going out problem.
Honestly I don't think it looks cheap, once its in the housing and the lens is on.
