Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
help with tailight issue
i have a 2001 325ci and about a week ago the tail light warning lid up on my dash, i checked the bulbs and everything worked fine, bulbs were not burned out and the connection was fine. i started doing some research and found out about the faulty break light switch, i went ahead and ordered a new oem one and swapped them out this morning. the warning is still lid up and now my break lights are on constantly when i start the car
my question is, after replacing the break light swtich, does it need to be positioned in a certain way that it touches the pedal a little or is it supposed to be secured inside the square to hold it in place? thanks for any input. appreciate it |
#2 |
the brake sensor should be adjusted such that when your not on the brake, the sensor is off. when your on the brakes, the sensor is on. the sensor is a magnet which should slide forward/backward for adjustment. make sure the sensor is not touching any metal when your not on the brake.
#3 |
And the break sensor is on the break light switch? The old switch was held in place in the square on the metal mount, and when I installed the new one I couldn't get it to stay in one place, although it is there, and makes sense about the magnet, I might have to reinstall it tomorrow
#4 |
Fixed it, changed the switch and couple of bulbs and it worked, figured out how to place the break light switch socket in correctly, thank you
