Old 09-23-2012, 10:07 AM   #1
Tun6twista
tun6twista
Tun6twista's Avatar
My Ride: 2001 BMW 330 CI
HID replacement kit question
I want to order the following...
D2S: Morimoto Elite HID System
I don't know what canbus wire harness I need to order for my 2001 BMW 330CI with existing Xenon lighting.
My existing balast or igniter fails after minutes of me turning my headlights on. It will turn back on again when I turn the switch off then on, but continues to fail between 1 and 5 minutes. Do I need the canbus 9006, H7, or 9007 wire harness? I've done an hours worth of searching.
Tun6twista is offline   Reply With Quote
Old 09-23-2012, 10:34 AM   #2
FastHackem
My Ride: E60 M5
None of those harnesses are correct for your application. If your car has a factory xenon system, its going to be a custom setup to install the Morimoto system. Not plug and play. Email TRS and ask them what your best option is.
Have you tried swapping your bulbs to isolate the problem? Sounds like a bulb issue to me.
Sent from my Nexus S 4G using Bimmer App
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 09-23-2012, 10:38 AM   #3
Tun6twista
tun6twista
Tun6twista's Avatar
Yes I have tried swapping the bulbs. same issue with either bulb. I have not swapped balasts yet. I just e-mailed TRS with my question. Thanks
Old 09-24-2012, 06:00 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Swap ballasts and get back to us.
Most likely the wiring on the ignitor is bad.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-16-2012, 11:11 AM   #5
Tun6twista
tun6twista
Tun6twista's Avatar
Reply...
So I finally ordered 2 new HID kits (one for the fog lights) and got to troubleshooting/replacing my lighting. Turns out the Ballast is fine. Swapped them and same light went out. Must be the ignitor on my drivers side. I will be replacing the OEM stuff and selling the working old ballasts to make up for the cost of the new kits. Thanks.
Old 11-15-2012, 02:10 PM   #6
rebelwitoutacoz
My Ride: 2004 330ci
do you still have the passenger side ignitor?
rebelwitoutacoz is offline   Reply With Quote
Old 11-16-2012, 10:25 AM   #7
Tun6twista
tun6twista
Tun6twista's Avatar
Yes I do. Someone else asked me this same question. I am not sure how to get the ignitor out as it is built into the headlight. Sounds like a pain in my arse. What do you think?
