Old 11-14-2012, 08:27 PM   #1
austin9888
My Ride: 2003 330cic
Peake Reader code 67 and 68
Hi guys to speed things up I got a rebuilt motor from a 5 series because my motor was seized. The mechanic that installed my motor slipped up in some areas... I had a code for the cam pos sensor, went to check the sensor, and there was no sensor in the motor... put one in and the code went away. Immediately after the code 67 and 68 popped up. Any ideas would be greatly appreciated
Thanks Austin
austin9888 is offline   Reply With Quote
Old 11-18-2012, 09:24 PM   #2
austin9888
bump anyone?
Old 11-30-2012, 05:04 PM   #3
austin9888
anybody? timing off? vanos? im going to replace the vanos and see what happens
Old 12-06-2012, 05:06 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
67 - VANOS, faulty intake reference value
68 - VANOS, faulty exhaust reference value
Off the top of my head a few things that can typical things that can cause those codes are;
bad/failing camshaft position sensor
timing being out
sticking VANOS solenoid pins
failed Vanos seals
