Old 11-14-2012, 09:48 PM   #1
Mflara20
My Ride: 04 330i
Help needed ASAP!!
Hey guys I change both intake and camshaft sensor and took the exhaust solenoid to clean it up because I believe I had a stock solenoid because of p0340 code. And now my car suffer to start and it sounds like crap! Please I need some help ASAP!!!
Mflara20 is offline   Reply With Quote
Old 11-14-2012, 10:54 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
Cant see video but have you plugged it all fully? Have you made sure to mark the solenoid so u when you put it back it goes in thr exact spot where it was?
Sent from my X10a using Bimmer App
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 11-14-2012, 10:55 PM   #3
Blocked Out
Have u disvonnected any grounds? Messed with ur coils?
IMG_1725
Old 11-15-2012, 08:46 AM   #4
Mflara20
My Ride: 04 330i
I didn't mark the solenoids :.censor and I didn't messed with any cooks and I made sure I connect them tightly. What would happen if by accident I swap the solenoids?
Old 11-15-2012, 10:48 AM   #5
Mflara20
My Ride: 04 330i
I fix the link, please I really need some help!
Old 11-15-2012, 04:24 PM   #6
Mflara20
My Ride: 04 330i
Anyone
Old 11-15-2012, 04:27 PM   #7
scim459
My Ride: 14 328i, 05 325cic
did you go genuine bmw or aftermarket?
scim459 is offline   Reply With Quote
Old 11-15-2012, 04:29 PM   #8
danewilson77
My Ride: 2004 zhp
So you replaced both intake and exhaust CPS's? Just wanted to clarify.
danewilson77 is offline   Reply With Quote
Old 11-15-2012, 04:33 PM   #9
Mflara20
My Ride: 04 330i
I replace both intake and camshaft sensors with aftermarket sensors from bavauto.
Old 11-15-2012, 04:35 PM   #10
Mflara20
My Ride: 04 330i
And took out both solenoid to clean them up that's all I did. What I do wrong??
Old 11-15-2012, 04:59 PM   #11
scim459
put old sensors back on and see if it fixes this. if it is then you should just go genuine. im not sure about the solenoid issue.
Old 11-15-2012, 05:03 PM   #12
Mflara20
My Ride: 04 330i
That's what I'm gonna do. But do you know anything about the solenoid issue?? Anyone???
Old 11-16-2012, 08:16 AM   #13
Blocked Out
You should ve marked the location of the solenoid so u turn in to exact same spot. Now its too late,youll have to clear vanos adaptations and reset it so the solenoid reads correct data now. You need a proper bmw diagnostic software to do so. Ex, DIS ,Inpa
About the cam sensors,swap old ones in and check and from now on use only oem or oe parts for your bmw,no more china parts.
IMG_1725
Old 11-16-2012, 10:00 AM   #14
Mflara20
My Ride: 04 330i
Do you know any good web page to buy the software from and the cable to connect my laptop to the car or do I have to go to my local stealership to fix it, or can rent the software from someone Im really desperate now.
Old 11-16-2012, 10:16 AM   #15
Wolrab
My Ride: 330Ci MT, 545i SMG
Not totally sure this will do it, but read through the thread and you'll find out. It's cheap.
http://forum.e46fanatics.com/showthread.php?t=893444
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-17-2012, 08:37 PM   #16
Mflara20
My Ride: 04 330i
Anyone??
