///M3 Forum
Old 11-08-2012, 10:03 AM   #1
YOLO89
My Ride: Hooptie
Higher mileage M3
Thinking about getting an M3 but within price range all have over 100k miles or close to it. Would I be running into issues possibly??
YOLO89 is offline   Reply With Quote
Old 11-08-2012, 10:19 AM   #2
obm3
My Ride: 2002 M3 & 2007 335i
Yes. If you can i would def buy it with a extended warranty of some sort. I purchased mine with around 90k a couple years ago. I've spent a small fortune in maintenace up to this point.
obm3 is offline   Reply With Quote
Old 11-08-2012, 12:33 PM   #3
illestminimike
My Ride: Project Drama
If the car has been taking care of and it has a lot of records to prove it then yes.
Old 11-08-2012, 12:37 PM   #4
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Originally Posted by illestminimike View Post
if the car has been taking care of and it has a lot of records to prove it then yes.
+1
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-08-2012, 02:28 PM   #5
S54Dan
My Ride: '05 M3 '03 ZHP
Anything over 100K+ is going to require the usual. Just remember most M3 parts are double regular non-m pricing. Good luck!
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 11-08-2012, 02:48 PM   #6
Firstboost
My Ride: 2006 Tiag ZCP
YOLO, so don't worry about it.
Firstboost is offline   Reply With Quote
Old 11-08-2012, 03:46 PM   #7
justanotherone
My Ride: 02 e46 m3
LOLOL I lol-ed. Then, I realized it was also in reference to his name, I lmao.
But, ya if there's a nice lengthy record of maintenance go for it. If there isn't, you might get lucky and it's been well taken care of. However, you might not get so lucky and start preparing yourself mentally to spend some good $$$.
Hope you buy it. Enjoyable car.
justanotherone is offline   Reply With Quote
Old 11-08-2012, 04:35 PM   #8
that1987
My Ride: Supra, Corolla, E46
I just bought 137K mileage M3 SMG and am doing coolant kit change, Brake pad change, valve cover change, complete oil and tranny flush, and all filters, plugs and fuel pump. Well $1500 dolalrs in OEM and good quality parts. Well worth the spenditure.
that1987 is offline   Reply With Quote
Old 11-08-2012, 07:08 PM   #9
Hi-LowBlow
I was in the same boat when i was lookng for an M3 (E46). Even after i purchased my car, I was still worried what will happen on my car. However, now i can say this with confident that the mileage is not the factor that we should be worried about. My 2006 M3 (smg) had 86k miles when i purchased it and now its got 95k in 6months but i haven't seen any small problems at all. I have been doing regular maintenance (including Inspection2 at 93k) though.
Don't worry too much!!
Hi-LowBlow is offline   Reply With Quote
Old 11-09-2012, 10:01 AM   #10
roadtrip1098
My Ride: 06 STi
If you're looking at one that has 100k, ask if the waterpump has been changed, also ask for proof of the Service Inspection II. Make sure the valve adjustment has been done. If it's an SMG, when you initially unlock the car you should hear the pump prime. If it takes longer than 10 seconds or sounds jacked up, walk away.
roadtrip1098 is offline   Reply With Quote
Old 11-09-2012, 10:35 AM   #11
scrace
My Ride: 03.5 M3
The only way I would buy ANY M3 is with all the service paper work, if there isn't a record....it wasn't done, it will save you all the headaches.
I bought mine with ~70k miles and spent ~$1.5k in doing all the preventative maintenance I could think of that the previous owner didnt do. When I bought the car it had new tires, brakes, rotors, clutch, guibo, tranny mounts, etc, a lot of the major non-DIY stuff (at least for me) was done.
Just my two cents. It also took me 3 months to find the right car.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 11-09-2012, 11:58 AM   #12
cak323i
My Ride: ///M3 & 330i ZHP
YOLO,
My ///M has 150k on the odometer...has been very well maintained throughout. If you can find an ///M that has been well maintained then it should be no problem but understand that you are getting a car with lots of mileage so there will be some wear and tear items to look into. Overall, I haven't had any major issues with my ///M and would do this again if I found one with high mileage but has been well maintained.
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 11-09-2012, 12:01 PM   #13
OfficinePanerai
My Ride: M3
bought mine with 175k on it and without doing a PPI. the deal was too good to pass up. that being said, i had to do full suspension and rear end overhaul. Now that its done it drives like a dream
[CENTER]
OfficinePanerai is offline   Reply With Quote
Old 11-09-2012, 12:19 PM   #14
taylor192
My Ride: 2003.5 M3
Wow! You must have gotten a steal!
I bought mine with ~70K miles on it without a PPI, yet Inspection II was done within the last year at a reputable shop (with paperwork to prove it) so I was satisfied that the car should be fine.
OP, as long as you can get a deal, there's no issue with getting a high mileage vehicle. Take the savings and catch up on maintenance. I've done $3K of maintenance on my M3 and I'm still ahead of what a lower mileage 2003 would have cost, and I have tons of brand new parts.
Old 11-09-2012, 05:28 PM   #15
cak323i
This
Old 11-11-2012, 04:29 PM   #16
vitalik-seattle
My Ride: 2004 M3
Bought my 04 smg with 98k for 10 grand. Screw the PPI it's a steal anyway. Currently have 106k and loving it. About to do diff and tranny flush, guibo and central bearing change.
My freedom is on 2 wheels =)
vitalik-seattle is offline   Reply With Quote
Old 11-11-2012, 11:19 PM   #17
CW23
My Ride: E46 M3
If the car has all paper work for repairs and all inspections done, I don't see why not to get one over 100k miles.
///M
CW23 is offline   Reply With Quote
Old 11-12-2012, 09:47 AM   #18
m3ane46
My Ride: 02 smg 2
a+++++ i have 178k still runing as long as you do everything on time and no rigs ur ok
i rag on it everyday intake header and exhuast side wayz for days lol
m3ane46 is offline   Reply With Quote
Old 11-12-2012, 05:44 PM   #19
AlbanianM3E46
My Ride: 2005 E46 M3
I have 187 and it runs ok, if something bad happen I ship to my home country, in tirana they cost alot of money.
AlbanianM3E46 is offline   Reply With Quote
Old 11-15-2012, 02:03 PM   #20
m3e46freak
My Ride: m Twee lol
100,000 miled vehicles are harder to finance...
Also check the maintenance that is THEE 100% most important thing..
then when you get it, have codes read and cleared and then do a hard reset of the full system (unplugged negative terminal for 5 hrs)
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
