///M3 Forum
Old 11-15-2012, 03:06 AM   #1
DevM46
My Ride: 02 m3
Weather change, supercharger sound???
I noticed that since the weather has got cold, on cold starts the engine would make a noise something like a supercharger & goes away when it's warm. I'm thinking its the pulley but not sure which one. Any thoughts?
DevM46 is offline   Reply With Quote
Old 11-15-2012, 04:44 AM   #2
lucky_doggg7
My Ride: 2005 M3
Goes away once the engine is warmed up... You gave a key piece of info there. Here is what I think is going on: when you fire the engine first thing in the morning, the car goes into "open loop" running, where the fuel injection system does not use the primary O2 sensors to determine the fuel air mixture. The engine uses some predetermined tables stored in the ECU to inject a predetermined amount of fuel based on outside air temp, but much of this atomized fuel since the engine is cold, condenses on the cylinder walls before actual ignition/combustion so warm up requires the injection system to provide more fuel than usual at idle. The colder the engine, the more fuel is injected into the cylinder to compensate for the atomized fuel condensing on the cylinder walls, also known as washing the bores (of oil). The colder it is, the more fuel is injected to maintain an idle, and more engine noise from combustion results, plus more vacuum, more air rushing through the ISV, etc, etc etc, during warm up.
After the O2 sensors come up to temperature and the engine temperature increases, the engine switches from "open loop" to "closed loop" where now the electronics are relying on the primary O2 sensors to determine the fuel air ratio. Once the engine is warmed up, the fuel no longer condenses on a cold cylinder wall, less fuel is used and the engine at idle is quieter in operation.
So there you have it.
Old 11-15-2012, 11:57 AM   #3
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Spot on !
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-15-2012, 01:02 PM   #4
sakumaxp
My Ride: 02 M3 convertible
hmm yeah mine "Squeals" this could be the culprit right here!
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
