Old 04-21-2015, 05:29 PM   #1
mangomagic
My Ride: BMW
Problem with headlight
Hi my head light (R) have been playing up, it flickers then sometimes goes off with his red headlight appearing on the dash (as per pic)
Do i need to replace the bulb? Or is it the wiring?
Any help would be appreciated
mangomagic is offline   Reply With Quote
Old 04-21-2015, 05:56 PM   #2
Davconelectric
My Ride: 2 dog powered sled
Sounds like a loose connection
Davconelectric is offline   Reply With Quote
Old 04-21-2015, 08:49 PM   #3
bumpgums
My Ride: bmw
Sounds like ignitor is failing. I would check the bulbs first then interchange the ignitors left to right. If issue mirgates then its the ignitor
bumpgums is offline   Reply With Quote
Old 04-21-2015, 09:22 PM   #4
doofdoof
My Ride: E46 330i
Is that Xenon headlights?
If so,
1. check if bulb is clipped on correctly
2. Check for loose connections
3. If still fails, swap bulbs from left to right to check if it's bulb issue
4. If still fails, swap ballast around to check if it's ballast issue
5. If you reach this point, it's coming down to ballast or wirings...
Good luck and stay safe... No mucking Around when lights are on...
doofdoof is offline   Reply With Quote
Old 04-24-2015, 06:13 PM   #5
mangomagic
My Ride: BMW
Thanks guys. This forum is awesome. Next day, my xenon headlight just started working fine again..and no red light flashing on the dash. weird!
Old 04-24-2015, 06:15 PM   #6
doofdoof
My Ride: E46 330i
It will come back... Take my word...
Old 04-24-2015, 06:32 PM   #7
KendrickC
My Ride: '03 325i
^ word. my mate has the same problem on the same light. except his is halogen projector.
'03 325 Estoril Blue with some love from:
Turner, ECS, Remus, BMW Performance, G.A.S.,
Beisan, Umnitza, TRS, Radium, and more!
KendrickC is offline   Reply With Quote
Old 04-24-2015, 08:05 PM   #8
mangomagic
My Ride: BMW
Did he ever find out what the problem was?
Old 04-24-2015, 08:18 PM   #9
KendrickC
My Ride: '03 325i
nope. I suggested it's possibly a ballast, but without eliminating all the other possibilities, it's just shooting in the dark.
Old 05-07-2015, 08:19 PM   #10
mangomagic
My Ride: BMW
Where is the ballast in the Driver's side?
Old 05-07-2015, 09:09 PM   #11
doofdoof
My Ride: E46 330i
It should be at the bottom of the headlights assembly. It's a silver coloured box...
Old 05-08-2015, 06:54 AM   #12
mangomagic
My Ride: BMW
So i need to open up the headlights assembly right? Thanks I'll try it tomorrow
Old 05-08-2015, 07:16 AM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Don't need to take it apart, it's mounted under the bottom of the headlight with a few screws. First swap your bulbs around and wait. If the light goes out now on the other side then replace the bulbs in a pair. If the light goes out on the same side again then swap ballasts over.
Old 05-09-2015, 12:21 AM   #14
mangomagic
My Ride: BMW
Ahh thanks. I finally took the bulbs out and swapped it. There's green gunk around the Driver's side igniter (side where I am having problem with). I can't seem to wipe it off and no idea what that is.. I'll prob have to take the whole headlight out
