Old 11-15-2012, 10:22 AM   #1
illestminimike
My Ride: 2003 SMG Vert M3
Corner Light Doesn't Work
I changed the bulbs and it still won't work. Checked the wires and everything is ok. It works sometimes but not all the time. It's the driver side one if that matters. What do I do now?
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 10:31 AM   #2
illestminimike
Should I switch the housings and see if that'll fix it?
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 10:31 AM   #3
choxor
Fully Deeked Out
choxor's Avatar
My Ride: An Automobile
Sometimes corrosion gets on the contact behind the bulb or it gets pushed in too far to make good contact. My old E46 had that problem. Hit it with a little sandpaper and electronics cleaner and bent it forward a little bit and that fixed it for me.
choxor is online now   Reply With Quote
Old 11-15-2012, 10:54 AM   #4
illestminimike
Alright I'll probably just do that when I get home.
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 11:12 AM   #5
BimmersGarage
My Ride: E46 330i
Send a message via Skype™ to BimmersGarage
Another thing to check it the white socket housing that holds the bulb.
That unit is replaceable (no cutting or splicing), you can swop out that unit with the passenger side and see if the problems transfers/follows. If so, just get a new housing unit and you should be solid. I had it happen to me and that fixed that random problem.
BimmersGarage is offline   Reply With Quote
Old 11-15-2012, 11:36 AM   #6
illestminimike
Thanks man. I'll try it out later today.
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 11:47 AM   #7
Platinum Plus Quality
My Ride: M54B30
+1 on checking all contact areas.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 11-15-2012, 12:28 PM   #8
illestminimike
Yes Mango.
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 06:32 PM   #9
illestminimike
Sanded down the contact area. Fixes the problem. Thanks guys.
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 07:52 PM   #10
choxor
Fully Deeked Out
choxor's Avatar
Old 11-15-2012, 08:59 PM   #11
illestminimike
Then I had sex.
-2003 M3 Vert
-1967 Mini Cooper
Old 11-15-2012, 09:42 PM   #12
choxor
Fully Deeked Out
choxor's Avatar
Then I had sex.
Old 11-15-2012, 09:58 PM   #13
haurelio
My Ride: 2001 bmw 325i
Good for you man..
Contact me if you need your att iphone unlock. Also can code your car
