Old 11-15-2012, 11:29 AM   #1
ECSTuning
ECSTuning's Avatar
My Ride: BMW
:: ECS Tuning :: BMW Upgraded M54 Aluminum Water Pump Pulley|Take one for a spin
We have a great looking, bolt-on solution for those wimpy plastic pulleys on your BMW water pump. Made of anodized aluminum, our black or silver water pump pulleys are way stronger than the originals, and will provide many miles of trouble-free performance.
Available in black or silver, these anodized aluminum pulleys bolt on fast, and are way tougher than the stock plastic originals they replace.
Click HERE for the Aluminum stock replacement pulley for your M54 powered E46
Old 07-01-2013, 02:01 PM   #2
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 04-03-2014, 11:10 AM   #3
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 04-06-2014, 03:11 PM   #4
RedFisch
My Ride: '00 323i, '01 330xi
Squealing belt
UPDATE: The below was not the fault of the pulley. It was a failing mechanical tensioner (even though it was only a few months old.
I just purchased two of the silver ones and installed the first in my 2000 323i (5speed) yesterday.
Unfortunately, even though I replaced the belt, water pump, tensioner and all pulleys about 5 months ago, adding the ECS pulley makes the belt slip and squeal.
At first I thought maybe the tensioner is already failing, but putting the old plastic pulley back on completely solved it. While the belt was off I checked the alternator and it spins fine and doesn't have a lot of play.
So I hate to say this but I am sticking with the plastic pulley until this is solved.
I will try the second one on my daughter's 2001 330xi just to be sure... Will let you know if the same thing happens.
RedFisch is offline   Reply With Quote
Old 04-07-2014, 10:53 AM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
On the E46 this is a direct replacement pulley, they are the same size as the factory pulley. With that in mind that's a rather strange issue your running into. Please feel free to contact our customer service guys (phone 1.800.924.5172 or email customerservice@ECSTuning.com) in regards to your issue.
Old 04-10-2014, 11:16 PM   #6
RedFisch
Originally Posted by ECSTuning View Post
On the E46 this is a direct replacement pulley, they are the same size as the factory pulley. With that in mind that's a rather strange issue your running into. Please feel free to contact our customer service guys (phone 1.800.924.5172 or email customerservice@ECSTuning.com) in rearguards to your issue.
OK, update! I put the other one on my daughter's 2001 330xi and it did not squeal. So I ordered a hydraulic tensioner for my 323i and all is good now.
Apparently the aluminum pulley will show a marginal tension earlier than the plastic, so it actually helped me in this case.
Old 04-11-2014, 09:38 AM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Awesome! Glad you got everything sorted!
-James
Old 09-02-2014, 02:03 PM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 09-02-2014, 11:27 PM   #9
aleksankazakov
My Ride: 04 E46 330i sport
Send a message via ICQ to aleksankazakov
I have used aftermarket water pump with metal impeller. After two and a half years the bearings failed and the pump started to stroke the engine. Here is what i filmed on this pump.
aleksankazakov is offline   Reply With Quote
Old 09-05-2014, 01:07 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 10-08-2014, 03:53 PM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E36 M3 ECS Aluminum Water Pump Pulley - Black
Click HERE for your E36 M3 ECS Aluminum Water Pump Pulley - Silver
Old 10-09-2014, 12:45 PM   #12
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E39 525/530 Aluminum Water Pump Pulley Kit
Old 01-06-2015, 02:03 PM   #13
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E85 Z4 Aluminum Water Pump Pulley
Old 04-29-2015, 02:20 PM   #14
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E36 M3 Aluminum Water Pump Pulleys
Old 04-29-2015, 04:32 PM   #15
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E46 325/330 ECS Pulley Options
Old 04-30-2015, 02:08 PM   #16
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E53 3.0 ECS Aluminum Pulleys
