Old 11-15-2012, 12:06 PM   #1
WDE46
My Ride: '13 128i, '04 330Ci
Thermostat stuck open
I just wanted to share some data with the forums. I have suspected since it started getting cold that my thermostat is stuck open somewhat. Today I have conclusive data of this. Below is a plot of my coolant temperature. It starts off at about 80C and dropping constantly. I started the data logging as soon as I got on the interstate, so it cooled a little from driving at about 45 mph to the ramp. You can see it continues to cool all the way to 72-74C at 80mph. It is obvious the time that I got off the interstate and then pulled into a parking lot at time 00:10:00. It then begins its climb back to the normal operating temperature before turning the aux fan on.
I should note that during this whole time, my temp gauge moved by only several degrees toward the cool side. If it is not DEAD center, you have an issue. I will be replacing everything but the radiator soon, and I will do that when I convert to the electric fan this spring.
Should be Coolant Temp (degrees C) vs Time...Torque pro doesn't have a good graphing system.
EDIT: Forgot to note the air temperature: 46-48 degrees F
Old 11-15-2012, 12:19 PM   #2
My Ride: Lexus
You didn't need an app to tell you that :-p BTW I ordered a bluetooth OBD2 adapter and downloaded torque. Should I buy torque pro? what does it do?
Old 11-15-2012, 12:30 PM   #3
WDE46
I know, but I just wanted to prove it to myself and I wanted to share what it looked like on the forums.
Torque pro made this graph.
From the torque page on Google Play:
The paid version has support for more vehicles and ECU types, looks a lot nicer, and works with more cars / trucks
The paid version has more features (HorsePower,Torque, 0-60 , quarter mile tests, graph data, map / track views) + no adverts and exra dial/display types! and better ABS / Knock sensor support, Transmission temperature support for some makes of car / trucks (GM / Ford, etc), and Turbo Boost on many more vehicles (including VW)
I think I bought it for the configuration and data logging ability. The horsepower, 0-60, 1/4 mile times are all useless estimations using the incredibly inaccurate accelerometers on the phone. All of the direct data logging and graphing and the dial displays work wonderfully with a bit of lag.
Old 11-15-2012, 12:35 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Get the Torque Pro for $5, it is worth it.
Still some issues with the program, however, the author has been updating things along the way, adding features and improving things.
Most graphing is lackluster on any automotive tool as the graphing is handled by the software guys without input from the car guys!
Oh, a BMW or German car thermostat stuck open or opening too early = NORMAL!
Temp gauge in the E46 is buffered, it stays at 12 o'clock for 50F swing in temperature.
Old 11-15-2012, 12:38 PM   #5
WDE46
I'm thinking this is giving me some poorer fuel mileage. It has gone down since getting colder around here and it should go up (denser and cooler air). My temp gauge also leans left a little when it's 45F outside. It was 32F the other day and it was twice as far over. After I replace my parts I'll graph it again at a similar temperature and share it here.
+1 on buying Torque Pro. It's worth the $5. It can reset our codes and read them.
Old 11-15-2012, 12:45 PM   #6
My Ride: Lexus
I'll buy pro.
Old 11-15-2012, 01:02 PM   #7
shanneba
My Ride: 2003 330Ci
Winter blend gasoline, usually starts in mid October, looses gas mileage, estimated at about 2-3%.
Have you checked your tire pressures? They go down also with colder temps.
Join BMWCCA
Old 11-15-2012, 01:05 PM   #8
WDE46
Haven't checked the tire pressures. That's a good idea since I last filled them when the temperature was still 90F at night. Either way though, my engine is running too cool.
I'll buy pro.
You won't regret it.
Old 11-15-2012, 01:38 PM   #9
GSherbs
My Ride: 2002 330 xi
can someone point me towards a proper bluetooth adapter that works with torque? There seem to be many to choose from
GSherbs is offline   Reply With Quote
Old 11-15-2012, 01:43 PM   #10
WDE46
Most of them looks identical to mine with a different sticker. I think some Chinese factory makes them and then companies resell them.
Mine looks identical to the "ELM 327 interface" that is all over Ebay. It has a different sticker but the same case and lights. Just search Ebay for OBDII bluetooth. Pick one.
The ELM 327 definitely works. I was just reading around real quick. Tons of videos with Torque/Elm 327 pair.
Also noticed my graph fits like a squashed version of the United States southern border.
