belt squeal maybe...? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 11-15-2012, 11:59 AM   #1
sakumaxp
My Ride: 02 M3 convertible
Question belt squeal maybe...?
well the weather has been getting colder these past few days and right when i start my car you immediately hear a squeal, for lets say 1.5-2 seconds, enough time for me to turn off my music and listen. ive read a few posts quick last night before my drive home from work, some were saying it could be a bad tensioner, glazed pulley, or just the belt rubber is cold and after its warm shouldnt be a problem, so i drove lets say, 2 miles down the road to fill up on gas and i turned my car on after, and it was gone. i assume the squeal has to do with the cold belt? if anyone has had this problem or knows what could be wrong please throw me some info.
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 11-15-2012, 12:02 PM   #2
najsauto
My Ride: 2000 BMW 323CI
I had a squeal in the engine bay but mine was the opposite: she didnt make noise when cold - noisy only after she was warmed up. I replaced belts and tensioner and no more noise.
Who knows though... if I were to guess I'd say that it's probably the belt tensioner or one of the pulleys acting up.
najsauto is offline   Reply With Quote
Old 11-15-2012, 12:03 PM   #3
sakumaxp
yeah i had my belts changed not too long ago, maybe about a week ago or so. and it only started yesterday, so ill see whats up when i start her up to go out later.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 11-15-2012, 09:11 PM   #4
illestminimike
My Ride: Project Drama
What kind of belt did you get? It really could be a pulley. Try this to make sure it's not something else: get in car and roll down windows and turn off music, then turn to ignition 2 without cranking it over and make sure it doesn't make any funny noises.
Old 11-15-2012, 09:21 PM   #5
$ilent ///M
My Ride: 03.5 M3 smg lsb
Mine was the pulley. theres two which normally go out the one by the alternator and one by a/c. you can put a long screwdriver close to it when cold and listen thru the screwdriver. r
$ilent ///M is offline   Reply With Quote
Old 11-15-2012, 09:59 PM   #6
choxor
My Ride: JDM
Did you inspect the pulleys when you changed the belt
choxor is online now   Reply With Quote
Old 11-16-2012, 02:00 AM   #7
Ballerbrian4u
My Ride: 2004 BMW m3
Is there any negative affect to this? Or is it just the noise? How much dose it cost to fix?
Ballerbrian4u is offline   Reply With Quote
Old 11-16-2012, 01:38 PM   #8
sakumaxp
i live in an apartment complex and when i moved i sold most of my tools, to work on my car since before i had a garage. so now i just take it to the shop unless im doing brakes and and an oil change.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 11-16-2012, 02:49 PM   #9
Rockyminator
My Ride: :)
It's the idler pulley.
HPF Stage 2.5 BMW M3
Rockyminator is offline   Reply With Quote
Old 11-16-2012, 04:02 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
If it's a pulley and it fails, yes. A belt can come loose wrecking fan blades and such, causing a lot more damage than replacing a belt and a few pulleys.
Old 11-26-2012, 01:29 AM   #11
Ballerbrian4u
So when I turn on my car In the morning until it warms up there is a squeal from the belt area. What do I need to check to see what the problem is? And what I need to buy? I was told by a friend to put some armor all on the belt to see of that helps. What do you guys think. Please helpppp!
Old 11-26-2012, 01:42 AM   #12
illestminimike
It's the tensioner.
Old 11-26-2012, 02:03 AM   #13
KrasivataSabine
My Ride: 323Ci
Had the same symptoms on my 323ci for two weeks. Replaced the belt, tenioner pulley, and idler pulley for less than $100. Both the tensioner pulley's bearing and the idler pulley's bearing were shot to hell. I replaced the belt for good measure. All is well now
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 11-26-2012, 02:04 AM   #14
illestminimike
Do exactly that!
Old 11-26-2012, 02:14 AM   #15
KrasivataSabine
My Ride: 323Ci
Originally Posted by illestminimike View Post
Do exactly that!
Why thank you
OP, its also an easy job to DIY so don't hesitate and just get to it!
Old 11-29-2012, 09:00 AM   #16
screamer-beemer531
My Ride: BMW M3 E46 6spd PY
Yh I've had that. I had a small VC gasket leak and it ruined the pulleys and the belt. Replaced them all and it went away. It used to be there only when cold just like yours. It's not an expensive job if you do it yourself.
"Failure is simply the opportunity to begin again, this time more intelligently." Henry Ford
screamer-beemer531 is offline   Reply With Quote
