Motor is not running very smooth keep getting p0303 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-15-2012, 07:06 PM   #1
omg A e46
My Ride: 323i
Ok so I changed my spark plugs about 2 months ago cuz it was misfiring and it's still misfiring. When I give it a lot of Throttle it starts to misfire then it gets a p0303 code then it won't stop misfiring until I shut off the engine and turn it back on. It happens about 8 times a day cuz I drive so much. And I know p0303 is Cylinder three misfire but how do I fix it. Could it be the coil pack on cylinder 3 ?
omg A e46 is offline   Reply With Quote
Old 11-15-2012, 07:08 PM   #2
omg A e46
My Ride: 323i
It's a manual transmission too sorry forgot to add that
Old 11-15-2012, 07:14 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
Did you try swapping coils around?
cvx5832 is offline   Reply With Quote
Old 11-15-2012, 07:21 PM   #4
omg A e46
My Ride: 323i
No I didn't try that yet. I will try it tomorrow
Old 11-15-2012, 08:09 PM   #5
cvx5832
If the code follows the coil, you have your answer.
Old 11-15-2012, 08:19 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Read the first link below in my signature for more info.
Old 11-16-2012, 10:16 PM   #7
omg A e46
My Ride: 323i
Ok so I switched the coil pack from cylinder 3 to cylinder 1. An it feels better from take offs. But it still kinda misfires when I give it a lot of throttle and not it won't throw a code. So I thing it's still that one coil pack.
Old 11-16-2012, 10:34 PM   #8
Nerdy46
My Ride: 328i
Try to get it to throw a code again. If it throws P0301 change the coil.
Nerdy46 is offline   Reply With Quote
Old 11-16-2012, 10:38 PM   #9
omg A e46
My Ride: 323i
I tryed to get it to throw a code but it wouldn't do it. And Before I switched it I could get it to throw a code no problem. So I think I will just buy a new coil and see what happens lol
Old 11-17-2012, 12:11 PM   #10
omg A e46
My Ride: 323i
Ok I got it to throw a code this morning and it was p0301 so it's a bad coil pack happy that it is a easy fix
Old 11-17-2012, 12:20 PM   #11
Nerdy46
My Ride: 328i
Nice work.
