#1 |
Some issues with trunk
So started up a car today for a drive. Noticed trunk wouldn't open with key, inside button or trunk button.
Opened it with the key and then closed. Tried again to open with key, trunk button and interior button. Bam! Worked just fine. After 10 minutes (or engine off and on) whole thing re-occurs. General electronics module? |
#2 | |
My Ride: '06 330CiC, '03 M5
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#3 |
Check for broken or almost broken wires in the wire harness between the trunk lid and trunk. Very common problem.
Sent from my Nexus S 4G using Bimmer App
![]() The Mind Is A Terrible Thing. 2004 Cayenne S 2005 Impreza WRX 2002 330i 1983 944 |
#4 | |
And fix is to splice new section of wire into the line as harness is prohibitive and impossible to install. Not literally. DIY's have been written. |
#5 |
Had no idea what Valet Mode is until googled it. Turns out that's not it.
Going to check wire harness between the trunk lid and trunk tomorrow |
#6 |
Intermittent electrical problems are the most difficult to find.
