Old 11-16-2012, 12:00 AM   #1
hungtran505
My Ride: 2002 Bmw 330CI
Sunroof won't close
Try to close my sunroof today and it close 3/4 of the way and then it stop. Try to close it all the way but my left side of the roof won't not move at all but it move side to side when I push the button either way. Any idea of what's wring with it?
Sent from my LG-E739 using Bimmer App
hungtran505 is offline   Reply With Quote
Old 11-16-2012, 12:21 AM   #2
E46Moonlight
My Ride: 2000 323i
Check the tracks if broken replace. If not lubricate. Is the motor making any clicking noises ? Also check the sun shade clips replace if broken
E46Moonlight is offline   Reply With Quote
Old 11-16-2012, 08:12 AM   #3
hungtran505
Yes the motor is working I can't get it to close so I can remove the glass part to check the track
Old 11-16-2012, 09:03 AM   #4
kaldE46
My Ride: 2001 325i
Take off the panel the button is located on. You'll see the motor. Take an allen wrench and you can wind the sunroof shut manually. Then tilt it and the six torx bolts will be visible for removal(3 on each side)
kaldE46 is offline   Reply With Quote
