///M3 Forum
Old 11-16-2012, 02:37 PM   #1
Vosvera
My Ride: E46 M3
SMG Issues (I need a tissue)
SO. I've finally decided to share my unfortunate experiences with the rest of the world.
My M3 has been having issues since I bought it in July of this year. The first issue I'd like to address is it has been falling out of gear on and off since I purchased it. When driving down the road, it would randomly fall out of gear and drop into "N", I would have to pull over on the side of the road. I tried shutting it down completely and waiting a few minutes, and to my suprise, after starting it again, it would go back into gear and I would be able to drive it. This has occured about 4 times. On the 3rd time it wouldn't start and I had to get it towed to a local shop. The mechanic installed a new altinator and she fired up without problems. He also used a diagnostic tool to see if any codes came up, and they did. He reset the codes and I was on my merry way... Until the fourth time.
The fourth time I was able to start it, and drive it around town for 5 minutes, until she fell out of gear again. I parked it on the side of the street and turned it off. I tried waiting with it off for a few hours, and it wouldn't start upon retrying, so i had it towed again. This time I did research online and found that the Salmon colored relay might need to be replaced as the symptoms matched that solution. (At this point the car wouldn't even prime when i unlocked the doors like it did before)
I installed the new salmon relay and reset the car's electronics by disconnecting the battery terminals and reconnecting them after a 20 minute wait. I unlocked the doors (and didn't hear a priming noise), put the keys in the ignition (electronics worked), tried to start the car and it made a funny noise above the steering wheel that i hadn't heard before, and wouldn't start. I had it towed to the stealership and they said it needed a new hydraulic pump and a slave cylinder, and potentially a clutch (they said the clutch arm was overextended).
anyone have any thoughts on this?
Vosvera is offline   Reply With Quote
Old 11-16-2012, 08:30 PM   #2
m3e46freak
My Ride: m Twee lol
Yes, did you try taking off the negative terminal for 5 hours straight? Do that..then get back to us to see whats next and if not I suggest you open your check book up, but not to the stealership find another shop
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 11-20-2012, 12:42 PM   #3
roadtrip1098
My Ride: 06 STi
There are a few items that are relatively inexpensive that can cause this, but you'll want to get your codes read ASAP to narrow down what the issue may be.
First off are the hood sensors, they are known to fail and can drop you out of gear.
Other symptoms you mentioned are similar to what happens if the driver gets out of the seat, so it is possible though I've yet to hear of such an instance that the weight sensor in the driver seat has gone bad.
Check the Hydraulic Fluid for the SMG pump (it's the cap beside the intake manifold)
Other possibilities are the compression springs which are a PITA to get to but relatively inexpensive or the temp sensor for the hydraulic fluid.
Again, the codes will need to be read, not just cleared to fully diagnose the issues.
roadtrip1098 is offline   Reply With Quote
Old 11-20-2012, 12:51 PM   #4
choxor
My Ride: JDM
So, those codes that your mechanic erased. Do you know what they were.
Old 11-20-2012, 06:06 PM   #5
illestminimike
My Ride: Project Drama
This. We need to know what the codes are and why does your mechanic think erasing then is going to fix it?
Old 11-28-2012, 08:27 AM   #6
steve bettencourt
My Ride: 2003 m3
there is a service to the SMG pump, the ball and spring same time change the transmission fluid
steve bettencourt is offline   Reply With Quote
Old 11-28-2012, 04:00 PM   #7
hoonpv
My Ride: Ford Falcon
You are ****ed bro! Smg pump time
my name is James and I like to have fun!
hoonpv is offline   Reply With Quote
2003 m3, bmw, dropping out of gear, e46, smg
