Old 11-16-2012, 10:25 PM   #1
Alexotronic
Alexotronic's Avatar
My Ride: 2001 330Ci
Checking fuel pressure with tire pressure gauge?
Hello, is it possible to check my fuel pressure with a basic PSI gauge? Or would that just give me a reading while spraying gas all in my engine bay?
Alexotronic is offline   Reply With Quote
Old 11-16-2012, 11:01 PM   #2
zabalzae
My Ride: 01 330ci
Haha
zabalzae is offline   Reply With Quote
Old 11-16-2012, 11:15 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
I mean....give it a try?
Old 11-16-2012, 11:32 PM   #4
Nerdy46
My Ride: 328i
pretty sure autozone rents a fuel pressure tester for free????
Nerdy46 is offline   Reply With Quote
Old 11-16-2012, 11:38 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
I understand it will work, use some towels to make sure you do not get too much spray.
Suggest you try initially without the engine running so you can get an idea how messy/dangerous it may get.
Proper fuel pressure gauge is the best approach in the end anyway.
Old 11-17-2012, 12:11 AM   #6
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
How/Did it work? Just curious.
Encryption76 is offline   Reply With Quote
Old 11-17-2012, 12:25 AM   #7
Alexotronic
My Ride: 2001 330Ci
Hrm. Even doing it with the engine off might be sketchy (fuel lines stay pressurized all the time I think).
I'm not COMPLETELY broke.. so no reason not to do it right.
Going to try and rule out other things for my rough idle first though. (Re-inspect DISA, elbows, ICV)
Old 11-17-2012, 07:08 AM   #8
jfoj
Fuel pump/pressure rarely causes rough idle, it causes other problems, but usually not at idle.
Suggest you read the first link below in my signature.
Old 11-17-2012, 12:52 PM   #9
RayPooley
My Ride: 320i SE Coupe
Give it a go and let us know what happens. Make sure you video it. We have a TV show in the UK called You Been Framed. They'll give you 250 for it.
Old 06-05-2015, 11:50 AM   #10
xhpssn
My Ride: car
fuel pressure test with the guage
I have always used a tire guage to test fuel pressure in many different cars , tested with tire pressure gauge was no difference when tested with a fuel pressure gauge, you can safely test with tire pressure gauge to check fuel pressure and no it is not dangerous , only a little but of fuel comes out not like these scary novice messages saying oh its dangerous high pressure and it'll go everywhere , no it won't I have done it many times , no difference than cleaning parts with gasoline , we do that all the time too . save your money and time use what you have to do the job.
xhpssn is offline   Reply With Quote
Old 06-05-2015, 11:56 AM   #11
Nicker
My Ride: 323ci
My thought is that the valve stem from the tire and the fuel pressure line are two different sizes and wouldn't fit to begin with.
Without a clean connection, you won't get an accurate reading.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 06-05-2015, 03:04 PM   #12
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It will NOT work. The fuel valve stem is inset Deeper.
Go get a real fuel pressure guage.
BMWCaptain is offline   Reply With Quote
Old 06-05-2015, 03:10 PM   #13
BMWCaptain
It will not work! Where did you get that idea?
