Closed Thread
Old 11-16-2012, 11:11 PM   #1
Nerdy46
My Ride: 328i
High Mileage Owners Check In.
Just bought a 328i with 192k on the clock. How long can these run with PM
Nerdy46 is offline
Old 11-16-2012, 11:42 PM   #2
Patton323I
My Ride: R1100GS E46 E53
For ever. A well maintained inline 6 is practically indestructible.
Patton323I is offline
Old 11-16-2012, 11:50 PM   #3
Nerdy46
My Ride: 328i
Figured as much. However my car is a sludge monster.
Nerdy46 is offline
Old 11-16-2012, 11:51 PM   #4
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
I know the feeling...
At 121k.
Encryption76 is offline
Old 11-16-2012, 11:56 PM   #5
omg A e46
My Ride: 323i
I got 205xxx on mine no major problems yet
omg A e46 is offline
Old 11-17-2012, 12:00 AM   #6
Encryption76
My Ride: 2000 328i
Your PO was good on maintenence. I would like to take a 1/2" drive ratchet to mine.
Old 11-17-2012, 12:00 AM   #7
Nerdy46
My Ride: 328i
Well... As soon as i got the car i started doing all the maintenance that it needed. When i pulled the VC i was amazed at how much crap was under there... I litterly took a paint scraper and scraped it off in to a trash can.... Then i blew it out with an air gun and hit it with a brush and some sea foam.... I then let it idle with a bit of sea foam in the oil after changing the VCG. Changed the oil and had no oil pressure must of clogged the screen with all the gunk... Reved it lightly a few times... pressure came back. Drove it around for about 1k and changed out just the filter. So far so good. Looks like its cleaning up nicely.
Nerdy46 is offline
Old 11-17-2012, 12:06 AM   #8
Nerdy46
My Ride: 328i
Nerdy46 is offline
Old 11-17-2012, 12:08 AM   #9
Encryption76
My Ride: 2000 328i
Mine looked similar only it looked like the valve cover was still on only black. Pretty bad.
Old 11-17-2012, 12:23 AM   #10
Nerdy46
My Ride: 328i
Ouch. Mine still runs nicely. Actually quieter before i started cleaning it. Little bit of a lifter tap now.
Nerdy46 is offline
Old 11-17-2012, 12:26 AM   #11
Encryption76
My Ride: 2000 328i
I got the same results actually.
Old 11-17-2012, 12:46 AM   #12
///MPR77
My Ride: 02 ///M3 Tri-Ped
295k checking in... there are other high mileage threads on e46f.
ZChild is north of 300k with the highest mileage I have seen on here.
I think I may be in second for highest mileage, but not sure.
No sludge whatsoever.
///MPR77 is offline
Old 11-17-2012, 12:56 AM   #13
Nerdy46
My Ride: 328i
I know alot of them seemed old just wanted something fresh. Didnt want a thread zombie.
Nerdy46 is offline
Old 11-17-2012, 01:22 AM   #14
FenderGuy05
My Ride: 2002 BMW 325i
Looking forward to matching some of these numbers...i'm at 105k right now, about to do VCG, kinda scared of what I'll see...but it was purchased at 92k, and passed Carmax inspection so I'm optimistic.
FenderGuy05 is offline
Old 11-17-2012, 01:34 AM   #15
323i E46
My Ride: 2000 323i
Just got mine at 126k. Not looking forward to what my valves look like.
323i E46 is offline
Old 11-17-2012, 01:49 AM   #16
2001BMW330ci
My Ride: 01 330ci
145k on mine so far and just got done chasing phantom sensor problems next is a full tune up!
2001BMW330ci is offline
Old 11-17-2012, 02:32 AM   #17
afstud
My Ride: 2003 ZHP 6-speed
224k well maintained miles, runs and drives beautifully.
2003 330i ZHP 6 speed
afstud is offline
Old 11-17-2012, 04:34 AM   #18
ryannel2003
My Ride: '04 Cadillac Deville
151k miles here. Bought the car earlier this year at 137k so far and have done standard maintenance. Runs great.
ryannel2003 is offline
Old 11-17-2012, 05:04 AM   #19
RangerDave
My Ride: '00 328i ZSP w/ 208k
Klaudia hit 175k a couple weeks ago. Bought her at 82k. Had the valve cover off to do vanos around 130k and it was clean as a whistle! I think the electronics, not the engine, will be the death of my car.
BMW - Suzuki - Jeep
RangerDave is offline
Old 11-17-2012, 07:52 AM   #20
kag64
My Ride: 2000 323i
When I bought my car it had 185k on it, I have done all the maintenance on it myself; many thanks to all those who have posted DIY's.
I've probably saved thousands of dollars by doing all work for myself, but I still have much work to do before I'll be satisfied.
Here's a small list of things I've done:
1. Cooling system
2. Tune up
3. Changed fluid in Trans(manual) and diff
4. New Control arms and Bushings
5. Front Struts
6. Rear Shocks
7. Tune up(plugs, fuel filter, air filter
8. Junk yard air box, PO had removed it and the maf in favor of a CIA system
9. New Maf and upper and lower boots
10. Rear subframe repair
11. Repaired wiring harness at exhaust CPS
12. Replaced Radiator support
13. Replaced front bumper carrier and shocks
14. New Brakes and hardware
Next is to tackle the Rear bushings, then 4 wheel align, and thinking about rebuilding the engine and trans. The last thing will be fresh paint...
Love this car, it's so fun to drive compared to a front drive. Another thing I like about it is everything is put together logically and even working on hard to reach areas isn't too bad.
kag64 is offline
Closed Thread
