Old 11-17-2012, 10:46 AM   #1
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Hear a slight "crick" when I accelerate/decelerate..
I've noticed that when I accelerate in 1st gear or decelerate in gear, I hear an ever-so-slight "crick" which seems to come from under the car just behind the front seats. Most people would probably not notice but I'm like most E46Fanatics who are sensitive to every little noise their autos make (or don't make). When driving, if I don't hear it upon deceleration, I won't hear it upon acceleration (such as at a stop light etc...) I also noticed that it makes the same exact sound (again, ever-so-slight) when I get into/out of the car which leads me to think that it might be suspension related.
Any ideas on what could be causing this?
HacksawMark is offline   Reply With Quote
Old 11-17-2012, 11:14 AM   #2
cvx5832
My Ride: 325Ci, 325Cic, C300
Or your seats. I had the same noise, it's the plastic trim that holds the memory seat controls, plus the cover to the control box itself.
You'll know what I'm talking about when you take it apart. In your hand you can torque it and replicate the noise. Search for the GoingNuts DIY for coupe seats, you'll see how to take it apart.
After that, you can do a variation on the actual solution. For me I cut small squares with BMW cloth tape and put it in between certain areas. The stuff I lay down was invisible upon reassembly, and the noise hasn't come back.
cvx5832 is offline   Reply With Quote
Old 11-17-2012, 11:57 AM   #3
HacksawMark
Thanks for the quick reply! I'll be sure to check it this weekend.
