Old 11-17-2012, 03:11 PM   #1
Mau330i
My Ride: '02 330i
Low Coolant Level Indicator sSensor
Hello Every one...
I have a little problem with my low coolant indicator. It seems not to be working although I have already replaced the sensor and expansion tank. If I disconnect the wires the light in the cluster works but does not if I push the floating rod all the way down.
Since I had an overheating problem a few months ago I'm a bit worried of not knowing if my coolant level is low.
Does anybody knows if there is a way to fix this or find where the problem is or how the sensor works??
Thanks in advance.
Mau330i is offline   Reply With Quote
Old 11-17-2012, 03:29 PM   #2
MojoJoe
My Ride: leaks fluids
Ensure you have the sensor installed facing the right way. It should go in with the cable connector facing the rear of the car, then turn clockwise (looking from underneath) to 'lock' it in (if I recall correctly). It is a simple reed switch and if installed the wrong way round the magnet in the float will be pulling it into itself rather than away, which is what breaks the circuit and triggers the light. Just a possibility.
MojoJoe is offline   Reply With Quote
Old 11-17-2012, 05:48 PM   #3
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Originally Posted by Mau330i View Post
Hello Every one...
Thanks in advance.
If u r worried about overhearting again then I recommend buying and installing a coolant snitch for your e46. Just search for it. Basically it is a module that will sound off with a loud audio warning before your car overheat.
I have this device and now I am no longer paranoid of catching my car overheating in time
sent from my dahc-6900 using Bimmer App
Old 11-17-2012, 10:45 PM   #4
Mau330i
My Ride: '02 330i
Thanks a lot for the answers!!!
coolant, coolant level sensor
