Old 12-14-2012, 09:08 AM   #41
bostonsc4
My Ride: BMW 323i
Originally Posted by B8888KC View Post
You should consider investing in a pressure pump so you can do a pressure test whenever you do a work on the radiator. E46s are vulnerable when it comes to fluid leaks, at least in my experience. I have replaced the expansion tank 3 times, the whole hose assembly once, even the cover thingy at the back of the engine and the water pump too. Have you replaced the oil and tranny cooler? You dont want the coolant or tranny fluid to go inside the engine
I think I could really benefit from one of those. My buddy may have one, I'll ask him today. But, I'm finding that the hose that enters the ET about 3/4 of the way down, not the lowest hose, but the one thats towards to bottom, that hose is the one I have that keeps letting go. I can't say for sure, but I feel like that hose can be pulled off the ET with just fingers even when its fully clamped. Not sure how to permanently correct that.
bostonsc4 is offline   Reply With Quote
Old 12-14-2012, 09:49 AM   #42
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
...new hose...
Old 12-14-2012, 02:33 PM   #43
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Plumber's tape. It fixed mine.
I did have to remove the ET to get to it.
You wrap the tape around the male end coming out of the ET right at the spot where it makes contact with the inside of the hose. I did probably 6 or 8 wraps.
Schlag96 is offline   Reply With Quote
Old 12-14-2012, 03:15 PM   #44
bostonsc4
My Ride: BMW 323i
I was fortunate enough to find someone willing enough to drive me back to campus tomorrow to help me fix it. I'm bringing some plumbers tape, and I just picked up some super heavy duty bond to itself stretch 3x its original state tape that I'll cover the entire connector with. Lets HOPE tomorrow is the day...
Old 12-14-2012, 04:21 PM   #45
WDE46
Weagle Weagle
WDE46's Avatar
Boat stores always sell stuff that is excellent for pipe fixes. Sounds like the tape you got is probably similar to what they sell. That **** will seal just about anything if you wrap it enough times and neatly enough.
