Old 11-18-2012, 12:03 AM   #1
hoodust
My Ride: Tuned 3 & Drift M3
Send a message via Yahoo to hoodust
Catalyst not ready
I finally fixed my p1188 and p1189 codes, cleared it and driven my car 300 miles following the driving cycle the past few days. With my OBD tool, only the catalyst not ready still remains, the other ones set easily with the driving cycle.
Anyone got some ideas?
Will it pass smog here in Cali with the catalyst not ready?
under modification DriftUNED
hoodust is offline   Reply With Quote
Old 11-18-2012, 02:03 AM   #2
lcoleman
My Ride: '79 Massey Ferguson
If Cali is like VA, it will not pass without all the monitors reset. Have you driven above 60mph, and also in slow stop-and-go traffic? There was a breakdown of the driving cycle necessary to reset them posted recently.
Old 11-18-2012, 07:42 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Not correct, matter of fact I just had one of my cars pass with 1 monitor not ready in VA.
VA and I think CA and other states have a graduated rule that may allow up to 2 emissions readiness codes to not be clear as long as the CEL light is not lit.
Usually the graduated scale depends on the year of the car, older cars many times allow up to 2 emissions readiness code to not be clear.
You need to check with CA rules, I am sure any SMOG station can answer the question and/or you can search the Internet for more info.
Usually the Evap codes may be the hardest to clear. Also many cars that have had CEL on for a long period that had to do with a specific system may delay the emission readiness for that part of the system.
Catalyst readiness sometimes requires a bit of highway driving to get everything warm & stable. So if your 300 miles has been in town, you may need to get at least 30 minutes at highway speeds?
Old 11-18-2012, 07:57 PM   #4
hoodust
passed smog test with catalyst not ready. the technician said as long its only one it should pass
Old 11-18-2012, 09:36 PM   #5
shovelit
My Ride: 03 325xi and 04 330x
In PA you are allowed 2 not ready for 2001 and older. 2002 and up is 1 not ready. Not sure about CA.
shovelit is offline   Reply With Quote
Old 11-18-2012, 09:40 PM   #6
jfoj
Kind of what I expected.
Again most states have graduated Readiness Indicators that cannot be set, the oldest cars may have up to 2, slightly newer cars 1, then cars usually less than 5-8 years old need all Readiness Indicators clear or passing.
Glad you got your car to pass, chances are in the next few days your last readiness monitor will clear anyway??
Old 11-18-2012, 10:08 PM   #7
hoodust
I hope so! i got my innova scanner plugged in while i was driving the past few days. The P1188 and 89 codes showed up again as pending codes luckily it didnt set of the SES light. the catalyst monitor is rhe hardest one, as of now it still shows not ready.
Old 11-19-2012, 08:33 AM   #8
jfoj
Suggest you read the first link below in my signature for your 1188/1189 codes.
Old 11-20-2012, 06:58 PM   #9
cyberkaa
My Ride: E46 332i,M3;E30 325i
Hmm, good to know. I've been trying to get the catalyst readiness monitor set on the M3 again (new battery). Took forever 2 years ago, too.
If we can get by with 1 not set, I might just try getting the smog check done now.
-Kalim
(klx photo studio)
Old 11-20-2012, 07:09 PM   #10
jdstrickland
My Ride: '94 325iC & '00 323i
There can be two monitors that have not been set.
Old 11-20-2012, 07:33 PM   #11
jfoj
Just make sure that the number of monitors are not graduated by year. Many states allow newer cars 1 monitor not set to pass inspection, then allow older cars 2 monitors not set to pass inspection. This is true as long as the CEL is not on!
Old 11-21-2012, 02:55 PM   #12
cyberkaa
Just got back from the smog check and my 2002 M3 passed with the catalyst readiness monitor not ready (confirmed still unset when I got back).
From the CA BAR site:
The maximum allowable readiness monitors for model year 2001 and newer vehicles is one unset monitor. Model year 2000 and older vehicles are allowed two unset monitors.
http://www.bar.ca.gov/PubWebQuery/ST...efinition.aspx
-Kalim
(klx photo studio)
Old 11-28-2016, 05:32 PM   #13
DavidValentino
My Ride: 2000 328ci
update
updated for those currently having catalyst monitor issues for smog in CALIFORNIA
Starting May 4, 2015, BAR plans to reduce the number of allowable incomplete OBD II readiness monitors for both BAR-OIS and BAR-97 inspections to the following new criteria:
Gasoline vehicles:
- 1996-1999 model-years are allowed one incomplete readiness monitor
- 2000 and newer model-years are allowed only an incomplete evaporative monitor
DavidValentino is offline   Reply With Quote
Old 03-05-2017, 11:28 AM   #14
Ricky1510
My Ride: 2001 BMW 330i
tips to pass smog - 2001 BMW 330i
I failed California smog because I recently cleared a check engine light after a DIY repair...not knowing my emission devices go into a "not ready" status. Disconnecting a battery will also do this. They all have to be ready prior to the smog test. Cat monitor was the most difficult.
Here are my tips: (1) Buy a Actron CP9185 for $80. This will allow you to determine which emission device are not ready. (2) Run the BWW drive cycle consisting of: (A) start cold engine, idle 2 min 10 sec, (B) drive 20 to 30 MPH steady speed for 3 min 15 sec, (C) drive 40 to 60 MPH steady speed for 15 minutes, (D) come to a stop and idle in gear for 5 minutes.
Notes: The Actron CP9185 is useful for future smog tests on newer cars since smog tailpipe emission test is less of a criteria and smog devices readiness is more of a criteria. "steady speed" is critical during the drive cycle. I used cruise control and drove at 5 AM to avoid traffic on the freeway since 60 MPH is relatively slow. It is best to go over the time requirements slightly than under. I had to do the drive cycle twice to get it right. I passed smog AFTER my Actron CP9185 indicates all my emission devices are ready.
Ricky1510 is offline   Reply With Quote
Old 03-05-2017, 12:52 PM   #15
jfoj
Disconnecting the battery will not clear codes or Readiness Monitors unless it is disconnected for 2 weeks or longer, this is part of the OBDII requirement that a quick battery disconnect will not clear codes or Readiness Monitors.
A few comments, for section C I wound not drive above 50 MPH and have found 45 MPH to be ideal.
As for an OBDII tool forget the Acton, while it make work, save yourself a bunch of money and buy something that does far more.
The OBDFusion App will run circles around the Actron tools.
If you have a smart phone or table, get an OBDII App and interface so you can read the codes along with Live/Realtime or Freeze Frame data then you will know exactly what is going on with the engine fuel management system.
The OBDFusion App and proper VeePeak interface from Amazon are less than $30 for both for iProducts, less than $20 for both for Android
OBDFusion for Android is is $3.99.
https://www.amazon.com/Veepeak-Bluet...peak+bluetooth
OBDFusion, for the iProducts it is $9.99.
For iProducts you NEED a Wifi adapter or LE Bluetooth adapter which are more expensive and VeePeak does not offer these yet..
iProducts requires Wifi - https://www.amazon.com/dp/B00WPW6BAE...ywords=veepeak
The adapter links I posted were some of the cheapest and smallest interfaces at the time, you should search and see if there are others that may be slightly cheaper but from what I have found the VeePeak interfaces have few, if any complaints.
