E46 Xi Forum
Old 11-18-2012, 08:48 AM   #1
76m2002
My Ride: 2001 325xiT
Front Diff seal leak
I've got a leak coming from the front diff on our 2001 325xiT. It is at the output flange on the passenger side, where the front passenger-side axle plugs in to the flange. It is definitely leaking diff fluid, as Redline 75w90 gear oil smells quite different than engine oil or CV joint grease.
Is there a seal here that I can replace? Like part #7 in the realoem diagram? Anyone done this while the diff is on the car?
76m2002 is offline   Reply With Quote
Old 11-18-2012, 09:48 AM   #2
325xittt
My Ride: 2003, 325 XIT
Its not to hard to do. I've replace 4 on the car. No need to remove the diff housing to do this. Find a good DIY on this site for the axle removal. Pop out the seal and replace with a new one. I'd drain the diff fluid and fill with new while you are at it. Also would be a good time to consider replacing CV boots. You will need a new axle end nut at the hub.
325xittt is offline   Reply With Quote
Old 11-18-2012, 11:37 AM   #3
djantlive
My Ride: E46 M3
I had a diff leak that was fixed with a spray on rubber sealer from home depot. It was easier than taking the diff apart and worth a try. Just clean the diff real well with brake cleaner so the sealer gets a good surface to bond to. If it doesn't work, you can peel or scrape off the rubber coating easily.
djantlive is offline   Reply With Quote
Old 11-19-2012, 06:30 AM   #4
76m2002
Thanks for the good news. I've never replaced one of these seals. Is it straightforward? I the seal just a cap that I pry off and hammer in a new one?
Old 11-19-2012, 06:55 AM   #5
325xittt
Yes the seal is essentially a cap. Pry/Pull it out, and tap a new one back in.
Old 11-19-2012, 07:33 AM   #6
76m2002
Thanks!
Old 11-20-2012, 10:46 AM   #7
Rickna
My Ride: '01 330xi - '09 IS-F
Make sure that the seal is square to the housing as you are installing it. Use a seal driver or rubber/wooden mallet.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
