Old 11-18-2012, 04:01 PM   #1
Hornung418
My Ride: '04 MB ZHP
How to turn on the CEL, Key On, Engine Off
Is there anyway I can physically fool the emissions inspector? I'm running EU2 software with MS42 DME and would like to turn the CEL on before start up and turn off when the ignition is started. I'm not looking to defoul any O2 sensors or any other crap. Simply wire or code the light to turn on when the key is on, and turn off immediately when the engine starts.
I only need to do this just to pass emissions. Not a permanent fix...Just a temporary solution.
Any ideas?
Hornung418 is offline   Reply With Quote
Old 11-18-2012, 04:02 PM   #2
jerseyzillest
My Ride: 325 CI
02 simulators are probably your only solution.
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 11-18-2012, 04:29 PM   #3
Hornung418
My Ride: '04 MB ZHP
Yes because my car is throwing codes...read. I'm looking to turn it on for the correct sequencing for emissions testing.
Sent from my SCH-I535 using Bimmer App
Old 11-18-2012, 10:27 PM   #4
j_block
My Ride: 2003 325i
I don't think you can do that? You have headers?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 11-18-2012, 10:35 PM   #5
Hornung418
My Ride: '04 MB ZHP
No headers. Planning on passing emissions and then installing them.
Old 11-19-2012, 12:06 AM   #6
Hornung418
My Ride: '04 MB ZHP
Had to think on it for a while. What about the oil pressure light. That's on when the engine is off and off when the engine is on. I think can snake some wire to those contact points and visually trick the inspector.
Old 11-19-2012, 01:25 PM   #7
j_block
My Ride: 2003 325i
So why not take off the euro tune? Then put back on after?
Old 11-19-2012, 03:00 PM   #8
Hornung418
My Ride: '04 MB ZHP
Because I deleted the SAP and broke a hose in the process. That was 18 months ago. Would be easier to just get it to flash on and then off when oil pressure is reached and the light goes out.
Old 11-25-2012, 02:02 AM   #9
Hornung418
My Ride: '04 MB ZHP
So Thursday I managed to get this completed. Just need to wait for Monday to come so I can hopefully pass emissions.
The plan was to use the Battery Signal LED to trip the CEL LED. I took a length of insulated copper wire and stripped 1/4" off of each end. Figured out that the combo that powers the LEDs uses the bottom solder point of the Battery Signal LED and the left solder point of the CEL LED. Once that conclusion was reached, I routed the wire behind the gauges and folded the ends over themselves as a locator; to keep the points in contact at all time. Sealed everything back up and gave it the test.
If anyone needs pictures of the actual setup, I can take pics before the removal of the copper wire.
Thanks for looking!
Old 11-26-2012, 11:00 AM   #10
Hornung418
My Ride: '04 MB ZHP
Passed emissions. There is now a solution available for headers and passing emissions without having to send the DME off to get coded/tuned.
Old 11-26-2012, 05:38 PM   #11
jamex
My Ride: 2005 325Ci
Good job. I think this may be a fairly unique and rare requirement to workaround, but its good to have the info on the site
I'm more curious to know if the tester would even have noticed the CEL not turning on during ignition sequence. I would bet theyre trained to see if it comes on or stays on, but not to look for if it pops up during key position 2.
Most people trying to keep the damn light off, not try and get it to turn on
jamex is offline   Reply With Quote
Old 11-26-2012, 07:08 PM   #12
Hornung418
My Ride: '04 MB ZHP
Thanks. When I went in two weeks ago, they failed me because it would not show. So this work around was devised.
Old 11-27-2012, 01:30 AM   #13
jamex
My Ride: 2005 325Ci
My hat off to you then. You didn't receive much help here and found a way to do it anyway
Color me impressed.
I should add that emissions testing is changing next year where I am. The sniffer is going away but I suspect I'll be dealing with odb scrutiny like you just experienced. Did they do any visual inspection under the hood or chassis?
