Sponsored by The Tire Rack
Old 11-19-2012, 09:15 AM   #1
MBarron330
My Ride: 2006 330ci
2006 330ci tire questions
Hi,
I just purchased a used 330ci, took to have a pre-purchase inspection, they noted that my driver side rear shock needed replaced, but did not mention the tire was worn on the inside down to the belts. My questions are.....
Could the shock be cause of the tire wear? The other three tires are wearing normal... Also noted, the car has 4 samesize tires, but specs say the fronts and rear tires are supposed to be different sizes.....how important is it to have different sizes, could this be part of problem? Also if anyone knows of repair shop/tireshop they trust in Houston(kingwood)? I'd appreciate recommendation
MBarron330 is offline   Reply With Quote
Old 11-19-2012, 09:25 AM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Welcome to the site! Your 2006 330ci is an E46 chassis so I've moved your thread from the F30 chassis forum over to the E46Fanatics wheel and tire forum.
A worn shock would not cause that excessive tire wear, sound like you should replace both rear shocks, the shock mounts (they're a wear item) and then have the car aligned. What size tires are on the car? You can run the same size all around.
Tim
tim330i is offline   Reply With Quote
Old 11-19-2012, 10:11 AM   #3
MBarron330
My Ride: 2006 330ci
Thanks Tim!
Clueless to navigating site!!
I thought Mine was e93? You obviously can tell I'm a BMW newbie!
Why are tires diff sizes anyway? First I've heard of...
Old 11-19-2012, 10:13 AM   #4
tim330i
E46Fanatics Owner
tim330i's Avatar
Can you post a picture of your car? The E93 is the 3 series convertible that did not come out until December of 2007.
Old 11-19-2012, 10:46 AM   #5
MBarron330
My Ride: 2006 330ci
Help?
ID:	478693   Click image for larger version
Old 11-19-2012, 10:59 AM   #6
tim330i
E46Fanatics Owner
tim330i's Avatar
You have an E46 with the ZHP package. Great looking car! What do you need help with exactly?
Old 11-19-2012, 12:16 PM   #7
MBarron330
My Ride: 2006 330ci
Thanks,
Do I "have" to put different size tires on front and back?
Currently it has same on all 4.... Driver side rear, worn to the belts, could being same size be part of reason? I do know I have to replace rear shocks, left leaking....
Old 11-19-2012, 01:21 PM   #8
tim330i
E46Fanatics Owner
tim330i's Avatar
No, you do not have to. I believe in some configurations the E46 came with the same size tires all around. Having the same size tires all around would not cause a single tire to wear out, as I said that is likely an alignment problem. You didn't post the mileage but your rear trailing arm bushings could be bad.
Tim
Old 11-19-2012, 03:02 PM   #9
Poncho@home
My Ride: MY04 330Cic ZSP
blown shock can also cause premature tire wear.
Poncho@home is offline   Reply With Quote
2006 330ci convertible, houston, tires
