Engine & Performance
Old 11-19-2012, 09:54 AM   #1
2.5-12
My Ride: 2000 323iT
09.03+ 325i Manual Transmission S5S 250G 22 tooth
this is a Getrag 250 trans from a september 03+ 325i/iC. under 50K miles on it. shifts like brand new. BMW wants over $3k for this transmission new.
this tranny is unique to the 04-05 model years (06 convertible) because of its 22 tooth input shaft which uses the same clutch as 90% of late model 6 speed BMWs instead of the 10 tooth which had been produced from 1991 till 2003.
this is a rare transmission, clutch kits are available searching 2004 325i 22T
will physically bolt to any M50 M52 S50 S52 M52TU M54 M56 N52 M42 M44 or M40 engine (may bolt to others as well.)
asking $350.
actual trans, 22T shaft.
reference photo, identical to:
2.5-12 is offline   Reply With Quote
Old 11-27-2012, 09:56 PM   #2
2.5-12
My Ride: 2000 323iT
bump
Old 11-27-2012, 10:15 PM   #3
Bmw0224
My Ride: 2003 BMW 325i
Where are you located?
Bmw0224 is offline   Reply With Quote
Old 11-27-2012, 10:16 PM   #4
2.5-12
My Ride: 2000 323iT
Minneapolis, MN.
right above my post count, too.
Old 11-28-2012, 03:19 PM   #5
Bmw0224
I would of bought it but I'm all the way in Cali
Old 11-28-2012, 03:33 PM   #6
2.5-12
My Ride: 2000 323iT
no worries, PMs replied -- I am willing to ship this guys. costs between 80 and 100 to lower 48 states.
Thanks!
Old 11-29-2012, 09:56 PM   #7
2.5-12
My Ride: 2000 323iT
rumpitybump
Old 12-02-2012, 10:59 PM   #8
Eric W
My Ride: 02 AA M3, 02 325ci
So if I had a 2002 5-speed 325ci build date 04/2002 this transmission would be a direct bolt on swap into my car except for me having to buy the correct 22T clutch and flywheel for it????
Eric W is offline   Reply With Quote
Old 12-02-2012, 11:02 PM   #9
2.5-12
My Ride: 2000 323iT
yes the trans is identical to the 2002 trans except for the input shaft.
buy the right clutch setup and you're golden.
Old 12-02-2012, 11:08 PM   #10
Eric W
Okay let me do some research on this. My current tranny's input shaft bearing is slowly going out, but I just dropped a ton of cash on the UUC. E34 M5 clutch setup an single mass flywheel. not sure what to do at this point,: Fix or replace the tranny
Old 12-03-2012, 11:58 AM   #11
2.5-12
My Ride: 2000 323iT
sounds good
Old 12-04-2012, 08:32 PM   #12
2.5-12
My Ride: 2000 323iT
bump
Old 12-05-2012, 10:30 PM   #13
2.5-12
My Ride: 2000 323iT
bump
Old 12-10-2012, 01:36 PM   #14
2.5-12
My Ride: 2000 323iT
bump
Old 12-12-2012, 01:18 PM   #15
2.5-12
My Ride: 2000 323iT
bump
Old 12-16-2012, 03:01 PM   #16
2.5-12
My Ride: 2000 323iT
bump
Old 12-18-2012, 10:51 AM   #17
2.5-12
My Ride: 2000 323iT
bump
Old 12-19-2012, 05:03 PM   #18
zha50
My Ride: '04 325ci 5MT
I may need this if I cannot fix my current one, cracked it at the drain plug. ... they are hard to find
'04 325ci M-sport 5MT
- Bone stock -
zha50 is offline   Reply With Quote
Old 12-19-2012, 05:28 PM   #19
2.5-12
My Ride: 2000 323iT
just keep me apprised, they are unreasonably difficult to come by, for sure.
Old 12-19-2012, 07:37 PM   #20
zha50
Problem is just not in the same country. Might be too difficult to ship. First point of call is welding, then trying to source a used one locally first.
- Bone stock -
