Old 11-19-2012, 05:25 PM   #1
willsbma
My Ride: 99 323i
Temp sensor
I tried searching for answers but my problem is a little different. My bumper was ripped off and the sensor went with it. I have a pair of blue wires just hanging there and a few plugs dangling too. I know one plug is my fogs, the other I'm not sure, my question (finally) is what color are the wires that go to the temp sensor? This is all on the driver side of the car and I can see the wires easily when the tire is removed. I think the one blue wire has small white dots/lines on it also
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 11-19-2012, 06:10 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
http://spaghetticoder.org/
Old 11-19-2012, 06:21 PM   #3
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
your bumpers has about 3 connections.
1) Temp Senor
2) Horn
3) Fog
if you still need help I can show you pix of the temp sensor and how to fix it. My temp sensor was ripped off also and it only took me 10mins to fix it.
Old 11-19-2012, 06:35 PM   #4
willsbma
My Ride: 99 323i
1) Temp Senor
2) Horn
3) Fog
Horns are hooked up, fogs are disconnected but I know which ones they are, one is just flapping in the breeze but I'm not really concerned with it, just the two blue wires that are ripped apart and hanging there. Do you remember the colors of the wire when yours ripped off?
Old 11-19-2012, 06:43 PM   #5
shanneba
My Ride: 2003 330Ci
This thread has pictures of the wires for the temp sensor.....first post lists the wire colors!
http://forum.e46fanatics.com/showthr...erature+sensor
Join BMWCCA
Old 11-19-2012, 06:48 PM   #6
flashmeow
Banned User
i think they were blushish in color
here are the pix...go here
http://forum.e46fanatics.com/showpos...&postcount=349
Old 11-21-2012, 05:00 PM   #7
willsbma
My Ride: 99 323i
I went and picked up the new sensor and the connector. Does it matter which wire goes where? They gave me white wires to make a new harness out of.
Old 11-21-2012, 05:11 PM   #8
jfoj
Should not matter what wire goes where for this sensor.
Old 11-21-2012, 05:33 PM   #9
willsbma
My Ride: 99 323i
Just finished hooking it up. FYI, the polarity does matter. One way I got +61 the other was +36. I used a cup of hot water to verify correct operation.
