I have an 01 330ci and it has just hit the 120k mark and have noticed the ride quality dip substantially. I'm looking to do an entire suspension refresh and wanted to know what you guys recommend should be replaced suspension wise on a high mileage daily driver. Thanks.
If you want to go for the gusto I'd look at doing the following; Lower control arms, Lower control arm bushings, Front stabilizer links, Front tie rods, Front strut mounts, Rear subframe bushings and hardware, Rear differential bushings and hardware, Subframe bushings and hardware, Lower wishbone bushings and hardware, Upper wishbone bushings and hardware, Control arm front bushings and hardware, Rear strut mounts, Z3 reinforcement plate, Rear stabilizing links, and of course new Hardware. If the shocks are originals there is a chance they are also worn and I'd look at replacing them as well.
Well, I do have packages which do exactly that. HERE is a link to them for the E46 330ci. We have a couple different levels repair with a few different brand options. If you have any questions about them feel free to shoot me a PM!
Does anybody know if i can put M3 springs on a 2002 325ci with sport package? do i need to swap out the strut/shocks as well or i can just replace the springs?
I recommend going with a site sponsor like ECS Tuning or Turner Motorsport. They have a lot of good pre-assembled packaged that have all the stuff you need for a suspension refresh.
Yes, you can, but if you do it will raise the front of the car and lower the rear slightly because the M3 has a heavier front end. It doesn't look very nice, and the ride will be bouncy with your stock dampers because they will be valved for softer springs and will likely be worn out as well.
Thanks for the feedback everyone. Will definitely look into a suspension refresh package. I'm excited.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
