Sponsored by The Tire Rack
Old 11-15-2012, 07:59 PM   #1
thecarguy
My Ride: ZHP Sedan
APEX ARC-8 in 17x9.5 concave on E46 sedan...
Can it work?
Through heavy searching I have not been able to find anyone that has or has asked the question but I'm thinking it might with spacers.
The plan would be to run that as a SQUARE set up with 255 40 17s all around.
I have an 05 ZHP sedan that is just begging for it! If not - 17x9 square it is.
thecarguy is offline   Reply With Quote
Old 11-15-2012, 08:40 PM   #2
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
it's possible, people were running 9.5+30 back in the day, this will be about the same...you will need to stretch 245s probably though if not smaller, run some camber, and do fender work
Chris
dreamdrivedrift is offline   Reply With Quote
Old 11-15-2012, 08:48 PM   #3
thecarguy
My Ride: ZHP Sedan
According to APEX's site the 17x9.5 is +35. The 17x9 is +30.
Old 11-19-2012, 06:31 PM   #4
David@ApexRaceParts
David@ApexRaceParts's Avatar
My Ride: E46 M3
We would not usually recommend anything wider than the 17x9.0 ET42 on the front of the e46 non-M as it would require a lot of negative camber and possibly fender work. The 17x9.0" ET30 concave wheel is too aggressive and would require a lot of negative camber in the front, along with a heavily rolled rear fender.
With the 17x9.0" ET30 squared setup, you would need the rear fenders rolled very heavily and the fronts to have a lot of negative camber dialed in, with 255/40/17 tires. If it is your track wheel, we highly recommend sticking to the 17x9.0" ET42 for the better fit.
David@ApexRaceParts is offline   Reply With Quote
Old 11-20-2012, 09:50 PM   #5
thecarguy
My Ride: ZHP Sedan
Thanks David, I was hoping you would see this. I just needed that confirmation and was curious if anyone did it and had pics. From some that I have seen, I am more than cool with the 17x9 ET42. Just need to find a buyer for my stock 135s.
Old 11-21-2012, 12:59 PM   #6
David@ApexRaceParts
My Ride: E46 M3
Sounds great! Feel free to give us a call directly if you have any other questions!
