Old 11-20-2012, 02:04 PM   #1
reupgang
My Ride: 2000 323i
Is it safe to say, if I don't have the CEL on, i'm good?
I've been doing maintenance on my car and followed many DYI on here, but I have yet to have a check engine light on in my 2.5 years of owner ship. should I not worry as much?
reupgang is offline   Reply With Quote
Old 11-20-2012, 02:11 PM   #2
Blueandwhite85
My Ride: E46
It's definitely a good start, but bad VCGs, OFHGs etc don't throw codes. If you are unaware of what to look for, have a trusted E46-aware mechanic inspect the car.
Blueandwhite85 is offline   Reply With Quote
Old 11-20-2012, 02:20 PM   #3
FenderGuy05
My Ride: 2002 BMW 325i
Agreed, had my car for a little over a year, no CELs, *knock on wood*, but am always lining up the next set of DIY to keep things running perfect. VCG, Vanos, and new intake boots are on the list for the near future.
FenderGuy05 is offline   Reply With Quote
Old 11-20-2012, 02:38 PM   #4
Wolrab
My Ride: 330Ci MT, 545i SMG
My "quick" check list is:
No lights on
No puddles under car
No clunking noises going over bumps
It gets a more thorough going-over each weekend, but that's basically my daily check.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-20-2012, 02:43 PM   #5
reupgang
My Ride: 2000 323i
I drive my car 1x a week prolly about 30-50 miles max, that a good thing right?
Old 11-20-2012, 03:42 PM   #6
WDE46
My Ride: '13 128i, '04 330Ci
The CEL/SES light doesn't know everything. For example, I completely snapped my DISA flap off to fix a rattle and the car has no idea. That's a pretty big item. Filters won't throw codes either and neither will a fuel pump or old spark plugs until they misfire.
Old 11-20-2012, 04:04 PM   #7
RayPooley
My Ride: 320i SE Coupe
Not a bad thing. Its enough to keep it healthy.
Old 11-20-2012, 04:08 PM   #8
Zell
Zell's Avatar
My Ride: so turbo wow
I haven't either, except the first time I bought it and the secondary air pump hose wasn't connected. CEL doesn't detect things like brakes, oil leaks, worn out belts, etc., but it does detect a lot, and if it's off, your engine is running well. You're good, OP.
Old 11-20-2012, 04:50 PM   #9
michalt95
My Ride: 02 325i MT
michalt95 is offline   Reply With Quote
Old 11-20-2012, 05:02 PM   #10
FenderGuy05
Originally Posted by michalt95 View Post
It's funny, I have honestly thought this from time to time. Just paranoia I think, especially with all the CEL horror stories I've read here. Guess the PO took good care of the car
Old 11-20-2012, 05:03 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
Your Check Engine light says SERVICE ENGINE SOON. This light should come on with the key in the RUN position before Engine Start, and then go out with the key in the RUN position after Engine Start.
If the light comes on before engine start, and goes out after engine start, then all is well with the engine management and emissions control systems. There are lots of other things that might not be so well, but engine management and emission controls are all working well.
Old 11-20-2012, 05:54 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
LOL
Not having any idea of what you've done, I have no idea. Personally, I think the car will give you warning signs often, which you shouldn't ignore.
Rub it behind the mirrors and it will tell you what's wrong.
Oh, your left rear is .2 psi low. (It's a blessing and a curse!)
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-20-2012, 08:31 PM   #13
drivesacrj
My Ride: 2000 323i
Had my car a couple of years now, no CELs at all. At one time I unplugged the MAF just to trigger the light and make sure it was working, and even then it took damn near half an hour!!
The light comes on at startup and goes away as soon as the motor coughs to life...
I got lucky with this car: bought it at an auction without prior inspection (theft recovery), didn't know anything about subframe issues at the time, luckily it's intact, no leaks, interior (leatherette) is pristine, motor and trans both silky, no dings or dents, no airbag issues, great mpg, ice cold A/C....looks like PO took care of it before it got jacked...
I am, however, looking to upgrade next year...
drivesacrj is offline   Reply With Quote
Old 11-21-2012, 01:24 AM   #14
TerraPhantm
My Ride: M3 & ZHP
The only time I ever got a CEL on my ZHP was when I unplugged the MAF. Even then, it took about 60 miles of driving for that light to get triggered.
On the M3 I've gotten one once due to mixed up O2s and once due to a bad TPS
