Health & Fitness
Discuss any topics related to heath and fitness here. |
#61 |
Think about this. Who's arms will be lower when the bar is on the chest. The guy with the shorter arms or the longer arms? Think elbow angle. A short armed lifter may have more of a right angle to the arm whereas the long armed lifter will be pushing from much deeper. That alone makes it harder for the long armed lifter to get the bar off the chest. It's the same idea when people bench without going down all the way to the chest. They want to lift more so they shorten the movement. I do agree that the top of the lift doesn't really matter though.
#62 | |
Chillin'.....Killin'
My Ride: M3/848/128i
IMHO, it's not about the bar being on the chest. To me, the hardest part about benching is controlling the load on the way down and controlling the load on the way up while keeping my form intact. Sure, the guy with the longer arms may have a further distance to push (..and I use the term "may" because longer limbs mean a different grip position than what is used by someone with shorter limbs; it's all a wash in my opinion. Benching is more variable, unlike....say, a squat or deadlift), but what needs to be done to move the weight is the same regardless of the height of the individual. To further clarify, there are multiple rings on a standard issue 45 lb. bar. Where I grip the bar (...just outside of shoulder width, pinky fingers or ring fingers on the closest ring from the smooth centered portion of the bar) is different than where my taller, longer limbed buddy grips (..his grip is much wider and closer to the outer ring). Our travel distance is about the same... ....and he puts up more weight than I do, and my bench numbers are strong.
#63 | |
#64 |
I also feel like the stronger the back, the better the bench. The lats/rear delts are significant components of the bench press. In fact, my lats handle majority of the load during the eccentric phase of the press.
#65 |
See I don't know how you can make that argument. It's just ONE variable out of many, and almost sounds like an excuse for people with long arms so they can have a reason. What about guys with less body fat compared to you/more muscle? Guys that weigh more than you? Guys that have better form and can breathe better? What about guy's that are short and deadlift more...is it cause they have shorter limbs? Or cause they are actually just stronger? Not to sound like a dick, but that's just what it sounds like, an excuse.
#66 |
My bench is embarrassing. That's really all I have to add to this discussion.
#67 | |
A 6'+ strongman athlete and a 6'+ endurance athlete look very different. Look at Derek Poundstone versus Michael Phelps, for example. There's a 3" difference in height, but the joint issue is still evident. ![]() ![]() Now, with that said, does it prevent longer-limbed guys from benching decent numbers? No, certainly not. But to suggest that limb length is solely a cop-out is equally ignorant as suggesting it's the only factor. It's also easier to take positions that benefit us, and is worth noting that you're below average height and don't have slight joints, so perhaps your view on it is a bit skewed.
#68 | |
To be fair though, the sheer thickness makes the power-lifters limbs appear shorter, but if he didn't have the muscle mass he'd look very different. Add 50+ lbs. of muscle to Phelps' frame and his limbs would look short too.
#69 |
While your point is completely valid, my point with the pictures was solely about joint thickness.
#70 | |
#71 | |
#72 |
#73 |
Yes, I agreed and said it plays SOME role, but not a "huge part" that was said before, and blaming the reason someone can't put up big numbers being cause they have short limbs is ignorant.
#74 | ||
you mad bro? seriously. I do my best to help others with the knowledge I have gained by researching health & fitness topics. You just seem to troll, what a great contribution... If you disagree with things I say, why don't you create an intelligent debate like everyone else?
#75 | |
There is no doubt that you are dedicated. That much cannot be disputed!
#76 | |
#77 | |
I promised him I wouldn't eat it and I beat him to the fridge and the egg nog was my punishment. |
#78 | |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
If you're tiny, you have to push the weight a much shorter distance. A much taller guy pushing an equivalent amount of weight is doing significantly more work. It's no different than the old notion that "the outside of a record is spinning faster than the inner portions". And not only is the distance an issue, but you also have the angle at which the bar hits your chest... dependent upon how "thick" your body is and the length of your arms, that angle will be much different. If you're a thinner guy with longer arms (like myself) your angle will be much steeper... if you're a thicker guy with short arms, you have much less work to do throughout the lift and your angle will be advantageous. Regardless, I wouldn't trade a single one of my 75 inches for additional weight on a bench press. Lastly, I've noticed people talking entirely different numbers in here. Some are mentioning their workout weights (10, 8, 6) which is what I did... others are talking max. Anybody making fun of anyone else's numbers is just a dbag.. if people are trying to continually improve, that should be celebrated (regardless of the mark). Would you mock a fat guy for "not losing weight fast enough?". Of course not. EDIT: FWIW, can anyone in here say they would actually take the strongman look over Phelps or other "cut" athletes? I know I'd take a WR or DB body type over a LB or offensive lineman any day of the week.
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() Last edited by 2000_328CI; 11-26-2012 at 01:21 PM. |
#79 |
My Ride: has free candy.
I was 180-185 putting up 245x6 when I stopped.
Haven't hit the gym in a month and a half, currently at 190. Can't wait to be done with school so I can get back into it.
![]() embrace this moment remember we are eternal all this pain is an illusion Last edited by DME46; 11-26-2012 at 01:23 PM. |
#80 |
Depends on what your goals are. I would love to lift heavy and have a slender lean build, though.
![]() embrace this moment remember we are eternal all this pain is an illusion |
