Old 11-21-2012, 01:55 AM   #1
Asher454
My Ride: '04 TiAg 325xi
New GKN CV axle, few questions?
How is supposed to feel? You guys feel any vibration at all (I don't). When the CV axle was bad the thud when I hit a bump kind of vibrated the steering wheel and now its mostly gone but it's still there a bit, Any way to remove the sound or feeling?
Asher454 is offline   Reply With Quote
Old 11-21-2012, 09:59 AM   #2
mcopenha
My Ride: '01 325xi, '73 2002
hey there, I just replaced my axles with new GKN's. I'm crossing my fingers that they'll be better than the Cardone axles I put in just 25K ago. The cardones started failing pretty quickly.
Before I did the job, my car's front end would make a stuttering sound when cornering. I blamed the problem totally on the axles, but when I disassembled everything I discovered that the lower ball joints on the control arms were totally shot -- boots ripped, no grease -- just flapping around. Replacing those made a big difference in front end noise.
That's an expensive fix though (but there is a guy on the xi forum who managed to replace just the ball joint), so I would first look at your sway bar end-links. When those go bad, your front end will make a clunking sound when going over bumps. Check those out first.
mcopenha is offline   Reply With Quote
Old 11-21-2012, 10:58 AM   #3
xi_ter
My Ride: 2003 325xi
Cv joint damage comes from the CV boots getting torn and then getting contaminated by road dirt and water. You then get a clicking sound while turning.
Did you get a torn boot first?
If not take it to an alignment shop for an inspection. Can be control arm bushings, end links, ties rods.
Old 11-21-2012, 01:19 PM   #4
mystert
My Ride: 2003 330Ci
GKN makes the OE axles for BMW so they should be a lot better than the cardone parts
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
