Old 11-21-2012, 10:09 AM   #1
diM3tri
My Ride: 330ci + stg2 Scoobie
How to install m3 seats into a 330ci??
I have been looking around for a DIY on this but i could seem to find one..
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 11-21-2012, 10:12 AM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Slide the seat all the way back and up, disconnect the battery (unless you have a Peake tool), unplug everything under the seat, undo the four bolts holding the seat down, take out, then do the reverse
Old 11-21-2012, 10:13 AM   #3
S85FTW
My Ride: E60 M5 & F30 328XI
Send a message via AIM to S85FTW
Lol really? Unplug battery, remove 4 bolts for each seat. 2 plugs underneath each seat, done.
S85FTW is offline   Reply With Quote
Old 11-21-2012, 10:14 AM   #4
diM3tri
oh its that easy? i thought i had to transfer things like airbag sensors and stuff over to the new seats?
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 11-21-2012, 10:32 AM   #5
S85FTW
Plug and play, no modification necessary.
Old 11-21-2012, 10:35 AM   #6
diM3tri
great, thanks!
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 11-21-2012, 10:46 AM   #7
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
The coupe is plug and play as pointed out above. The sedan takes some more work, make a DIY (i think) when I put M3 seats in my old 330i.
Tim
tim330i is offline   Reply With Quote
Old 11-21-2012, 10:56 AM   #8
Zell
Zell's Avatar
The side airbag sensors are bolted directly to the car under the seat. It is under the foot vent for the rear passenger, fairly hard to get to. Just don't kick them
Old 11-21-2012, 11:28 AM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
There is no DIY. Just like there is no DIY on how to open the hood.
As with pretty much everything, they suggest you disconnect the negative post from the battery. Then you take the old seats out and put the new seats in. There are plugs under the seats that you have to work with, but it is all very straight forward -- like how to open the hood, except you need a wrench.
Old 11-21-2012, 11:50 AM   #10
InZain08
My Ride: 330ci
Good luck with installing the seats man, I've always wanted to do the same
InZain08 is offline   Reply With Quote
Old 11-21-2012, 11:56 AM   #11
Alex323Ci
My Ride: M3 & 323Ci (sold)
yep either disconnect battery or be absolutely certain to Not turn the key on. or else you will get an airbag code that needs specialized software to reset.
the seats are plug 'n play with the exception if it has heat or power if yours did not. Then you may need to wire some things up. remember to have your power seats moved so you can access the nuts/bolts before cutting power. also put a thick towel at the threshold so not to scratch stuff up moving seats in/out.
Old 11-21-2012, 12:40 PM   #12
diM3tri
Thanks everyone for the advice! The seats I'm looking at are the same specs as my current: power, heat, lumbar etc so I shouldn't have any problems with doing this!
Current Cars:
'13 GLI
Previous Cars:
'82 VW rabbit vert
'01 330ci
'84 633csi
Old 11-21-2012, 12:56 PM   #13
jdstrickland
The only thing to caution you about is that the donor car have the same number of doors as the your car. If you have a 2-door and the donor is a 4-door, then you won't have the lever to tile the seats forward so people can get to the back seat.
Old 11-21-2012, 01:00 PM   #14
jdstrickland
ONE MORE CAUTION
Do not turn the key to RUN without having both seats plugged in, else you will trigger an airbag (SRS) fault that requires more diagnostic capability than you have to reset.
SRS goes out and looks for all equipment to be installed and working else a fault is triggered. Given the importance of this safety equipment, they do not allow generic scan tools to access the system. There are scan tools that will reset the system, but you can avoid buying one of them if you remember to not turn the key on until both seats have been plugged in.
Old 11-21-2012, 01:41 PM   #15
tylermaslanik
My Ride: 3 Pedal 323Ci
Yeah as long as its the same seats its plug and play. I got power and heated M3 seats for my manual seats and had to run the wires from the fuse box. That was a pain. but worth it. haha
tylermaslanik is offline   Reply With Quote
Old 11-21-2012, 02:22 PM   #16
shahbaz99
My Ride: Clean 330ci
be extra cautious when pulling the seats in and out of the car. those brackets underneath are sharp and can work a nice number on your door panel, door jam and your dash.
shahbaz99 is offline   Reply With Quote
Old 11-21-2012, 03:10 PM   #17
cvx5832
My Ride: 325Ci, 325Cic, C300
DIY
cvx5832 is offline   Reply With Quote
Old 11-21-2012, 03:14 PM   #18
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
coupe should be a direct swap/plug and play so this should be no trouble for you. I have a sedan and M3 seats. It was not a direct swap since I have to swap out the rails and seat belt.
Old 11-30-2012, 05:49 PM   #19
mightymouse777
My Ride: 01 325Ci
is it still a direct swap if you dont have heated seats etc prior?
mightymouse777 is offline   Reply With Quote
Old 11-30-2012, 05:51 PM   #20
tylermaslanik
I don't think so. You still have to run the wires from the fuse box. As they were not run originally.
