Old 11-21-2012, 05:55 PM   #1
austinadrew11
My Ride: 2001 BMW 330Ci
Flip Key!!!
Is there a way to boost the transponder signal? I have a flip key case and the chip is too far away from the ignition. What you guys think?
austinadrew11 is offline   Reply With Quote
Old 11-21-2012, 08:05 PM   #2
Stinger9
My Ride: '04 330Ci
wish I knew what your question is?
Old 11-21-2012, 08:12 PM   #3
SHOoff11
My Ride: 1999 Lexus LS400
Any way you can move the chip closer? Cut and re-solder or something?
Originally Posted by SPDSKTR
You drive a BMW. That means you make $600,000 a year and date supermodels without pointy elbows or hairy arms. Need I say more?
2001 BMW 330ci vert 5-MT Steel Grey/Tannin Red
1993 BMW 325i 5-MT Black/Tan
2010 Chevrolet Silverado 2500HD Z71 Summit White/Black
SHOoff11 is offline   Reply With Quote
Old 11-21-2012, 08:24 PM   #4
austinadrew11
Is there a way to increase the signal of the transponder chip so I can start my car with my new flip key?
Old 11-21-2012, 08:34 PM   #5
austinadrew11
I don't think so
Old 11-22-2012, 11:25 AM   #6
Hammer432
My Ride: 2001 330i 3 pedals
Did you transplant the chip from an old key? Did you order a flip key with a proper chip that matches your EWS?
Hammer432 is offline   Reply With Quote
Old 11-22-2012, 04:23 PM   #7
austinadrew11
Yes, I tried using the circuit board from my last key, but I put it back into my old housing so I can drive the car.
Old 11-22-2012, 06:22 PM   #8
eneka
My Ride: 2003 325i
you can probably move the chip closer..somehow..in the plastic valet key it's just a block sitting inside the key
eneka is offline   Reply With Quote
Old 11-23-2012, 01:11 PM   #9
austinadrew11
I have to be careful with whatever I do, because I only have the one master key.
Old 11-23-2012, 01:16 PM   #10
sea6speed
My Ride: 2010 335i Msport 6MT
What is preventing you from ordering another one from the dealer?
sea6speed is offline   Reply With Quote
Old 11-23-2012, 03:01 PM   #11
jfoj
My Ride: 330CiC, M5, X5, E93
$160!
Old 11-23-2012, 03:12 PM   #12
sea6speed
$160!
If $ is preventing having 2 keys disassembling your one working key is pretty dumb.
Old 11-23-2012, 03:28 PM   #13
austinadrew11
my key still works fine after i put it back together
Old 11-23-2012, 03:36 PM   #14
///MPR77
My Ride: 02 ///M3 Tri-Ped
In before:
" I ruined my only key; is it possible to start my e46 with a screwdriver? "
Old 11-23-2012, 03:58 PM   #15
austinadrew11
anybody know a way to move the transponder chip closer to the top of the circuit board without damaging either one?
Old 11-23-2012, 04:39 PM   #16
jfoj
Yep, one working key is foolish!!
$60 for a wallet key, you can harvest the transponder from inside the key head as it is more of an encapsulated transponder like the older keys with the LED.
Or just mount the wallet key inside the steering column so the wallet key always registers on the EWS!
Old 11-23-2012, 04:52 PM   #17
austinadrew11
Not a bad idea. Any way i can get one cheaper
Old 11-23-2012, 05:58 PM   #18
jfoj
Yea, if I buy it and mail it to you!
Otherwise you can try www.BMWpartssource.com
330ci, bmw, e46, flip key, key
