Australia
Old 11-23-2012, 05:40 AM   #1
M3N7AL
My Ride: E46 M3
E46 M3 Vert Cabin Noise
I've got some issues with rattles and in cabin noise with my e46 vert.
Does anyone know how to get these fixed? Very rattly and annoying.
A lot of noise comes from the passenger seat/door, rattles with the back of the cabin etc.
M3N7AL is offline   Reply With Quote
Old 11-23-2012, 05:55 AM   #2
Chewy
My Ride: '03 LSB M3 Vert SMG
You need to lubricate/rejuvenate the seals
Chewy is offline   Reply With Quote
Old 11-23-2012, 06:05 AM   #3
M3N7AL
My Ride: E46 M3
Have you had the same issue? Where can i buy the lubrication from and/or who does it?
Old 11-23-2012, 07:23 AM   #4
selien
My Ride: 330CI
fu*k do what I do and turn the music up, problem solved
Sent from my GT-I9300 using Bimmer App
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 11-23-2012, 10:21 AM   #5
Chewy
All verts have the same problem. It happens when seals go old and harden up. This causes them to rub against other windows, rubber and plastic, etc which causes the noise.
Many people recommend using gummi phlege.
Also windows needs to be clean
Interesting read below.
http://www.m3forum.net/m3forum/showt...light=vert+top
Old 11-23-2012, 08:15 PM   #6
djantlive
My Ride: E46 M3
i did all the cleaning, lube on all seals, weather strips. it didn't help.
i also tried putting in some foam weather stripping into the seals. it did nothing
then i removed the door panel and tighten the window regulator, it removed some of the chatter
there is still a lot of noise. i don't get it because my other verts (porsche 996 and 944) don't have this much noise
i just lower the window a little now. seems to work but it's not ideal
djantlive is offline   Reply With Quote
Old 11-23-2012, 09:37 PM   #7
Chewy
^ something must be lose on your car then
Old 11-24-2012, 03:02 AM   #8
KOpower
My Ride: 325ci
Just try interior detail your car - especially make sure stuff in glovebox and door compartments are not moving around
In my other car a glass perfume bottle was the culprit - i thought it was secure - but at high speeds it vibrates
Rattles suck balls - but just clean - organise - use meguairs interior cleaning products - tighten loose parts - and good luck !
My Ride:
2002 e46 325ci Manual - Sport & Premium Pkg
KOpower is offline   Reply With Quote
Old 11-24-2012, 03:59 AM   #9
Chewy
Also if you get wax and polishes in grooves and seals, it will make squeaks
Old 11-24-2012, 05:19 AM   #10
M3N7AL
My Ride: E46 M3
It's coming from the passenger seat and the rear.
Old 11-24-2012, 05:36 AM   #11
BMW//Blonde
My Ride: 330ci
Funny you say that my aunty took her Merc vert into the dealer thinking she had a rattle and it turned out to be a lipstick in the glove box
I'm getting rattles a bit too lately it sounds a bit like when you go on one of the newer buses and the windows make a cracking noise.
Would advise to check seat belt clips as i've found them to be one of the main culprits for rattles in mine.
Originally Posted by THE_dude View Post
Doesn't matter what blondes do, we still go nuts for them
Originally Posted by ASSAIL View Post
the real question is "do you drive an f-car?"
on that note i drove a 355 f1 gts the other day......i did chap laps all day trying to find a red vert.....
Originally Posted by N4NOOK View Post
No dice, i thought she dosen't roll with silver arrows, only maranello up in this vag!
BMW//Blonde is offline   Reply With Quote
