Old 11-24-2012, 04:14 PM   #1
DillonMpower
My Ride: bmw 330 ci
Is Boil over a big problem ?
i talked to a few guys about coolant in there cars, and I have heard a magnitude of things such as: water its plenty fine (distilled of course), "water wetter" helps but only in certain cars, anything gold (coolant wise) will work from german cars because it contains an oil additive such as the blue stuff from BMW, and if a car runs "hot" then over boil can be a real problem for disappearing coolant.
last question if boil over is a real problem can make water evaporate in a closed system ?
getting ready to do a fluid swap in my car and need some info on coolant misconceptions
DillonMpower is offline   Reply With Quote
Old 11-24-2012, 05:15 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
You think way to much about this.
Clear your head , go grab a gallon of Prestone and a gallon or water (dont matter distilled or tap) and change your coolant.
Dont think to much about such simple things.
PS, the car will never run hot or boil over if your cooling system works properly. Dont matter what coolants in it and what color it is.
Original BMW Teile ///
IMG_1725
Old 11-24-2012, 05:34 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP,
Blocked is right that you're overthinking this, but, as far as I know, only one coolant other than OE meets the specs for our car...that's Zerex G-05 I think...but don't quote me.
That said, the most important thing is to change it as per the bottle--I think OE says every 3 years.
Drain completely from engine block drain, rinse with straight distilled by filling up the system with it and driving a bit with heater on...let car cool and drain it. If it's filthy, do it again...then replace crush washer and use OE/distilled mix.
Blocked is right that changing it is more important than what you use...sort of...but there are some issues with gunking if you mix the wrong coolants...and then there are additives that bmw coolant has that are compatible with all the materials in our system. For many here, using OE is just the way to go...and in many ways, avoids many issues.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 11-24-2012, 07:15 PM   #4
wildirish317
My Ride: 2004 325Ci vert
If you have salts building up around the faucets in your house (as I do), don't use tap water. The salts will precipitate out and coat various places of your cooling passages that you really don't want caked with salt. Distilled water costs less than $1/gallon at Kroger. If you use it, you won't be wondering if your tap water is okay to use.
Also, when removing the drain plug from the block, keep a firm grip on it. The pressure of the water coming out is a bit more than what you get from draining oil, and it will push the plug out of your fingers and lodge it some place around the engine mount that will take hours to find.
I use BMW coolant because it's not that much more expensive than any other coolant, and the local BMW dealer is five miles from my house. Plus, the Bentley manual warns against using coolants containing phosphates. There's a LOT of debate about coolant on this site. Use whatever you want. Just don't leave it in the car for 10 years.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 11-24-2012, 08:33 PM   #5
Stinger9
My Ride: '04 330Ci
+1 on the distilled water. It's too cheap, you leave it in there too long, and minerals can cause too many problems not to spring for the cheap gallon of distilled!
Most all coolants in this country contain no phosphates any longer. I use Prestone that says good for all cars on their site and the bottle.
http://prestone.com/products/antifre...st#product-378
Old 11-24-2012, 08:41 PM   #6
BartenderPlease
My Ride: '03 540i/6 M-Sport
Don't use prestone or any brand autozone carries. They are too acidic for our alum blocks over time.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 11-24-2012, 08:54 PM   #7
Stinger9
My Ride: '04 330Ci
Funny statement because I check my coolant for pH regularly and it always tests neutral.
Old 11-24-2012, 10:44 PM   #8
illestminimike
My Ride: Project Drama
Where's Mango?
Old 11-25-2012, 02:47 PM   #9
Blocked Out
Lol. Can you prove that???
Sent from my X10a using Bimmer App
IMG_1725
Old 11-25-2012, 06:42 PM   #10
cvx5832
My Ride: 325Ci, 325Cic, C300
Prestone 50/50 (the one with no silicates, phosphates and other "-ates") since 2009 and 53k miles on the 325. No problems and no corrosion when I opened her up recently for a new water pump.
cvx5832 is offline   Reply With Quote
Old 11-25-2012, 09:24 PM   #11
My Ride: Lexus
No. But you also can't prove using ACEA A3/B3/LL-01 spec oil is better for our cars than conventional oil.
You just do certain things because it's spec'd or recommended by the manufacturer. A whole $19? Wow. Can't put food on the table, now. Aw, shucks.
OP, my advice to you:
1) Replace the entire cooling system.
2) Use Genuine BMW coolant and distilled water only.
The right way costs pennies.
The wrong way be fine, but on the other hand *may* cost you your engine.
You pick.
Old 11-25-2012, 09:40 PM   #12
Alex323Ci
My Ride: M3 & 323Ci (sold)
Use distilled water and BMW coolant (or equivalent spec).
bleed the system properly
top off as needed
change it every few years
Old 11-25-2012, 09:52 PM   #13
My Ride: Lexus
I was at the auto parts store the other day and this place had all kinds of coolant. jaguar, bmw, mercedes, toyota... and the generic stuff!
You could be cute and use the Xerex G-05, but it's like $2 cheaper.
ID:	479643   Click image for larger version
Old 11-25-2012, 10:03 PM   #14
Stinger9
My Ride: '04 330Ci
How did you know my friends all tell me I'm pretty cute?
Old 11-25-2012, 10:09 PM   #15
My Ride: Lexus
I may be 3,000 miles away but DMAX gives me updates on all the NY/NJ fanatics.
Old 11-25-2012, 10:20 PM   #16
Stinger9
My Ride: '04 330Ci
That does explain quite a bit then.
Old 11-27-2012, 07:47 PM   #17
Blocked Out
I sure can. I want to start an oil conversation , just tell me so...
But proving that synthetic oil is better then dino shouldn't take long...
IMG_1725
Old 11-27-2012, 10:49 PM   #18
My Ride: Lexus
Plenty of people here run conventional oil in their cars and have well over 200,000 miles. Sure properly spec'd synthetic oil is better than conventional oil in demanding conditions and you and most of us are willing to spend more money for it.
Why aren't you willing to spend a few more bucks for the proper coolant w/ distilled water?
Wrong car for you, my friend if you continue to keep taking shortcuts like that.
Old 11-27-2012, 11:12 PM   #19
lcoleman
My Ride: '79 Massey Ferguson
G-05 is for American cars, though I hear it is used in Mercs as well. I think G48 is the "modern" OE BMW fluid. I would probably just use the regular 'ol off-the-shelf Zerex green:
Tap water is fine, distilled is better.
This isn't as complicated, or as life-or-death as many members would lead you to believe. The horse has also been beaten to death here.
Running conventional oil is foolish, there is no net gain in an engine designed to work with synthetic. Take advantage of the much longer service intervals!
Old 11-27-2012, 11:22 PM   #20
My Ride: Lexus
Interesting thing is the S52B32 was designed to run on conventional and was even spec'd for conventionial. For the later 98 and 99 years (maybe just 99--i forget) BMW spec'd Genuine 5W-30 synthetic for the same engine. This was when BMW was redoing their whole service recommendations and swtiching to lifetime bla bla
coolant, water, water wetter
