Australia
Old 11-24-2012, 09:58 PM   #1
selien
My Ride: 330CI
Air not working
Hey guys, did a search and couldn't find much, what I did find kinda didn't relate to my issue.
Im experiencing a issue with my heater/air conditioning.
When turned on, on heat or cool, it basically does nothing, it blows extremely slow, even when turned all the way up.
Turning the air conditioning on, I can hear the compressor kick in but still nothing.
A few weeks ago I had worx look at it, and he found a error with one of the temp sensors, the one that sits ontop of the radiator fan.
He cleared the code and it ran fine for a week or so. The issue has come back even after I replaced that sensor and it shows no error code.
Anyone experienced this? or know where I should start looking at?
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 11-24-2012, 10:06 PM   #2
jamesbice
My Ride: 2001 M3
Sounds like a dud final stage resistor. A bit of a pain to remove and install but the probably the first thing to try. They sell them on clickable
jamesbice is offline   Reply With Quote
Old 11-24-2012, 10:47 PM   #3
DesiredM
My Ride: E46 M3
Yeap it's your FSR, happened to me in my 330Ci as well. Pain in the ass to replace but I guarantee that's your issue.
DesiredM is offline   Reply With Quote
Old 11-25-2012, 01:48 AM   #4
selien
My Ride: 330CI
thanks guys, ordered my replacement from clickable.
I cant find this resistor, i got under the dash, glove box side cant find it, followed the DIYs to the letter, is it under our steering wheel on rhd models?
Sent from my GT-I9300 using Bimmer App
Old 11-25-2012, 02:07 AM   #5
DesiredM
My Ride: E46 M3
Yeap you followed a US DIY
Follow this one
http://forum.e46fanatics.com/showthread.php?t=794644
Old 11-25-2012, 03:22 AM   #6
Tiag46
My Ride: e46
Goodluck. The hidden screw is a pain in the ass!
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 11-25-2012, 04:25 AM   #7
Pants.On.Fire
My Ride: 328ci
Good luck! The screw as mentioned, killer. I used a light and a camera to take a picture so I could see what I was feeling around in. I didn't put that screw back. Working fine, 2months.
Pants.On.Fire is offline   Reply With Quote
Old 11-25-2012, 04:53 AM   #8
jamesbice
My Ride: 2001 M3
If you have an iPhone you can put it in video mode, turn the light on (flash) and you can use the camera and screen to locate it. It's a complete bitch to get to. I didn't replace it which was fortunate as my second fsr died too.
Old 11-25-2012, 05:22 AM   #9
Tiag46
My Ride: e46
lmao, I did the same thing too!
Oh, and ur neck will hurt for a few days lol
Old 11-25-2012, 01:40 PM   #10
selien
My Ride: 330CI
Follow this one
champion! Thanks!
God getting underneath the glove box yesterday killed me, I layed down on my seat on my back to get my huge head under there, not sure how well it work with the steering wheel there now.
Old 11-25-2012, 06:25 PM   #11
dsio
My Ride: E46 328i / 330ci
The allen key sizes supercheap / repco had were A) Too short (couldn't reach that damn screw) B) Too long, fowled on the bit of steel 4 inches in front of it or C) Too thick, and couldn't fit down the narrow guide into the screwhead.
Ended up cutting the shaft off a long narrow one, then glueing it into the penlid off a white-out pen to get a tool that worked... that job sucked hard.
2000 330CI Sienna Red 5sp Manual
dsio is offline   Reply With Quote
Old 11-25-2012, 06:46 PM   #12
jamesbice
My Ride: 2001 M3
Yep the driver length is a pain in the ass!!
Old 11-25-2012, 07:51 PM   #13
dan_1337
My Ride: 330CiC
Did mine a week ago. Used a T-20 torx attached to couple of small extensions with a bendy elbow attached to another extension, attached to a small ratchet.
Didn't put the screw back in when putting it back together to make it easier for future FSR replacements.
dan_1337 is offline   Reply With Quote
Old 11-25-2012, 09:22 PM   #14
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
you can probs do it with a SAMSUNGPHONE too!
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 11-25-2012, 10:52 PM   #15
Ballistic325
My Ride: slow and steady
There's a UK dude who wrote up a DIY for RHDs. He took out the driver's seat and lay down comfortably to do the replacement.... said he was too tall and too old to contort himself under the steering and dash with the seat in!
I'll find the DIY for you and post it...
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-25-2012, 10:59 PM   #16
Tiag46
My Ride: e46
^lol.
