Old 11-25-2012, 02:19 AM   #1
certify
My Ride: 328i 2000
Engine full of sludge. What are my options?
Today I open my engine as I DIY valve cover gasket. But to my shock the engine are full f sludge.
ID:	479552   Click image for larger version
certify is offline   Reply With Quote
Old 11-25-2012, 02:25 AM   #2
warriorpluto
My Ride: 2000 323i
I say got Damn! I hope mind doesn't look like that. I still have original vanos seals at 200k. There is some stuff that cleans it out good but I don't remember the name.it's in another thread. But what I do remember other members saying is get as much sludge you see by hand and do the rest with auto rx.I think that's the name. One member engine was worse than yours and it cleaned up fine.
Sent from my SCH-I535 using Bimmer App
warriorpluto is offline   Reply With Quote
Old 11-25-2012, 02:58 AM   #3
certify
My Ride: 328i 2000
Ok thanks. I will try that
Old 11-25-2012, 03:39 AM   #4
05graysport
My Ride: 46/325 B5/S4 39/M5
Probably should drop the oil pan first and see how much is truly in there. Try 1/4 can seafoam about 100-150 miles before your next oil change and that should take out most of it.
05graysport is offline   Reply With Quote
Old 11-25-2012, 03:44 AM   #5
certify
My Ride: 328i 2000
Can i get those at ace hardware?
Old 11-25-2012, 06:13 AM   #6
330iPilot
My Ride: Titanium Silver 330i
Autozone, O'Reilly, Pep Boys, most any auto parts store.
330iPilot is offline   Reply With Quote
Old 11-25-2012, 06:33 AM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
www.autorx.com
Old 11-25-2012, 06:37 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 on seafoam for sludge like that. What's the history with that engine? What oil is used and how often? Do you take short trips with the car?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 11-25-2012, 06:41 AM   #9
jfoj
Also check the thermostat using the Hidden OBC Menu in the 3rd link below in my signature.
Have seen many problems with engines running slight cold and bad CCV causing this type of issue.
Old 11-25-2012, 06:51 AM   #10
My Ride: Lexus
Something like that really needs to be done by hand. Lots of brake cleaner and lots of rags. You might even want to soak it in gasoline for a while to help persuade it out of there. GL!
Edit:
be careful theres NO debris left over. you really dont want that stuff clogging any oil passages or the lifters. Then you'll have bigger problems!
Old 11-25-2012, 07:38 AM   #11
330iPilot
Hey Mango. After he cleans all of that should he do another oil and filter change after 1000 miles or so?
Old 11-25-2012, 08:43 AM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, I agree with Mango that you should start 'manually.' I'm actually wondering how bad it would be for a wet/dry vac, but if it was me, I'd care less about a cheap vac than an expensive engine.
You'd certainly need to change the oil again soon after...and frankly, the best solvent for sludge is oil. AutoRx, seafoam, etc. are so aggressive, I'd worry about dislodging so much so quickly that it does indeed get in places you don't want.
Maybe if you sprayed it all down with a parts cleaner than then blew it out with compressed air? You could rinse off the outside part of the engine later...just be careful with parts cleaner as you don't want it sitting on your paint too long.
I'm going to vote against using those magic formulas.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-25-2012, 08:56 AM   #13
jgold47
My Ride: 2004 X5 3.0
search user barneyhypen. He just did an engine that looked like that and it came out CHERRY. I think he said he used some oil eating bacteria (no ****), but it was done at a shop. assuming he didnt photoshop the picture, it looked amazing when he was done...
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 11-25-2012, 09:16 AM   #14
shovelit
My Ride: 03 325xi and 04 330x
I'd be pretty carefull using degreasers around the cam bearings. You don't want to remove all the lube from there.
shovelit is offline   Reply With Quote
Old 11-25-2012, 09:34 AM   #15
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
most people on here will disagree but if you search the internet/forums (especially old american muscle car site) people will recommend that you use Automatic Transmission Fluid.
if you are cautions but still want to use ATF then try this:
-empty your car completely of oil. Fill ATF until it fills the entire crankcase/engine. Let it sit for a few days without starting the car. Drain ATF and open your Valve cover and it should be spotless
-if you are a risk taker (I have tried on my e46 many times already)...then change out your oil. Drop it a quart of ATF (do not overfill engine). Drive around for a few hundred miles or just let your car sit at idle for a few hours. after just drain the atf/oil mix.
Old 11-25-2012, 09:56 AM   #16
dmax
dmax's Avatar
So,flash, how much atf is that? You mean fill using about 3 gallons to get the oil all the way up into the cams?
As crazy as it sounds, I think it sounds like a pretty good idea! I'd maybe try using atf under the vc first and sacrificing a wet/dry vac first though.
What's remarkable to me, though, is that OP, evidently, hadn't had an issue because of this.
OP...I think you should do one early oil change, and then, probably another pretty soon thereafter...if you can't find any oil eating bacteria--which also sounds like a great idea.
GL!
Mangofy your E46!
Old 11-25-2012, 10:43 AM   #17
Nerdy46
My Ride: 328i
Start with a brush. Then high pressure on an air compressor with a blower nozzle
Nerdy46 is offline   Reply With Quote
Old 11-25-2012, 10:47 AM   #18
flashmeow
Banned User
GL!
Dmax,
I never tried the overfilling method since I don't have sludge but yes, that is what I have been told. Fill the car to the top until the cams are covered in ATF and just let it sits for a few days.
Old 11-25-2012, 11:01 AM   #19
My Ride: Lexus
From Texaco's website:
Myth #12 - Adding a quart of ATF the day before an oil change will clean your engine. ATF added to the motor oil will clean the engine due to the high levels of detergent in ATF.
Fact: ATF does not contain detergent chemistry. ATF does contain dispersants, which have properties similar to detergents. But ATF is not formulated to withstand the combustion environment inside the engine. Havoline recommends that you keep the fluids where they belong: motor oil in the crankcase, and automatic transmission fluid in the transmission.
Old 11-25-2012, 11:20 AM   #20
HBizzo88
My Ride: 2002 bmw 330ci
Poor half a can of sea foam in the crankcase. Drive for about 50 miles, then change your oil. Should be good after that.
HBizzo88 is offline   Reply With Quote
