Old 11-30-2012, 10:16 AM   #41
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Someone on here had much worse. They manually removed it all, I think a shop vac with a pre-filter bucket was used. Search around, I remember the thread because the results were impressive.
Tim
tim330i is offline   Reply With Quote
Old 11-30-2012, 11:55 AM   #42
jhaurimn
My Ride: 01' 330ci
Auto rx, look into it
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 11-30-2012, 12:39 PM   #43
adaseb
My Ride: 2002 BMW 320i
You sure you don't have a bad head gasket and coolant mixed in with the oil?
adaseb is offline   Reply With Quote
Old 11-30-2012, 03:19 PM   #44
|2eckLesS
My Ride: 2004 330ci
update:
Yesterday made multiple runs and logged some loose temps over the last two days.
Interstate driving after 20 minutes (sat for 4 hours)
131-149F outside temp 55F
Hit Traffic and stop and go for 10 minutes
185F consistent outside 55F
Sat overnight ~35F
On the way to work this morning -no traffic, few lights
104-122F outside temp 38F average 113F while car should be warm @74MPH
On the way to Lunch today (Sat 6 hours)
158-185F outside temp 65F
Radiator Fluid is at minimum level and had it flushed by Stealership on 8/3/12 ~ 4k miles since then.
Theory
I think the flush on the system may have induced a crack in the cooling system. And now there is air in the system not allowing the water to properly flow through the heater core causing these low temps. This does not explain the rough idle unless the crack has been there before and oil has already started to sludge. The two problems could be non related at all, and rough idle be numerous different things.
Plan of attack
Stop by BMW today and pick up thermostat and bmw antifreeze (and distilled water)
Bimmersoftware has been ordered and wire should be in mail soon for true data logging.
CCV needs to be replaced regardless
Cooling System needs to be replaced.
Fuel Pump needs to be replaced.
I am going to do one by one and see if I can normalize my operating temp and idle. They all need to be done regardless, so time to start some winter wrenching. I often work 60-70 hour weeks so Sunday is really the only day I can tackle larger projects. Anyone have any advice or change of plan ideas?
|2eckLesS is offline   Reply With Quote
Old 11-30-2012, 03:35 PM   #45
330iPilot
My Ride: Titanium Silver 330i
You would see milky white crap mixed in with the oil if that was the case.
330iPilot is offline   Reply With Quote
Old 11-30-2012, 03:37 PM   #46
lcoleman
My Ride: '79 Massey Ferguson
Thermostat needs to be replaced, dude. The car should run around 200F no matter what driving coditions or ambient temp.
A couple of oil changes with a high ester oil and a properly working thermostat would help clear out that sludge.
Old 11-30-2012, 06:12 PM   #47
|2eckLesS
My Ride: 2004 330ci
I hope that is the case, but this is the perfect time to take a few free weekends and replace some potential threats to the e46 and learn about how they are put together. This is my first BMW of 13 vehicles and the first one that intimidates me about it's engineering. Only way to tackle that is head first. Stopped by BMW to pick up some antifreeze and out of curiosity asked how much to replace just the thermostat....538.20
Old 12-01-2012, 09:22 AM   #48
ryansser
My Ride: 2003 325i
Holy crap. When mine went bad, I went to a local indy, and they quoted me three hundred and I thought that was rediculous! I did it myself for the cost of a t-stat(55) and coolant(15)!!
ryansser is offline   Reply With Quote
Old 12-01-2012, 09:41 AM   #49
WDE46
My Ride: '13 128i, '04 330Ci
Don't fear the car, just respect it. It's really no more complicated than any other modern car. They're actually not too hard to work on.
Old 12-01-2012, 02:56 PM   #50
TerraPhantm
My Ride: M3 & ZHP
That's because most dealerships are full of crooks. The thermostat should really be no more than an hour's labor.
Heck, I had an Indy replace my entire cooling system for less
