330ci feel slippery on corners. With Dunlop star z1 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 11-28-2012, 03:35 AM   #21
ajai
My Ride: 330ci***65104; 328i
Originally Posted by Scooby24 View Post
Did you have an alignment performed after the coilovers? If not, that's a problem, for sure. If so, do you remember the specs? I'm also on BC Coilovers, full drop front to rear and as long as the temps are up, I have no problems at all on tires that are not as sticky as yours.
what psi u on?
Will camber setting affect tire psi needed? And do I need to increase psi in rain?
do u feel bc coilover is so stiff that the rear fly off and dsc goes on on bumpy road? and if soft, it bounce.
What setting is ur bc!?
Mine is front 16 from soft rear 13
Got any better ideas?
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 11-28-2012, 03:37 AM   #22
ajai
My toe I remember is 0.1 toe out
Old 11-28-2012, 03:46 AM   #23
mkodama
mkodama's Avatar
If your car has toe out and your tires pressures are at what you said, it's no surprise your car feels unstable. Just set the alignment to the BMW specifications, and the tire pressure to what is listed on your door jamb or owners manual. If your mechanic can't do what you ask, time to move to another mechanic.
You may not be able to get the camber and caster to within specifications, but just have the alignment aim for equal measurements on both sides and to get as close to the BMW specifications as possible, and everything will be fine.
Old 11-28-2012, 07:41 AM   #24
ajai
My total toe is 0.2
Which left 0.1 right 0.1
Is that good or bad?
Old 11-28-2012, 10:09 AM   #25
ajai
Originally Posted by SeanC View Post
seriously?
Psi = Pounds per square inch.
Pounds = lbs.
And you're low on air. 35 lbs per square inch is where you should be at. Clear now?
Sent from my SGH-I997 using Bimmer App
Thanks for advice . I am at 34 all around now.
The traction is better, and response is faster. But a bit lighter steering. Will 34 be too high for mine?
Also I see the door said font 2.9 bar and rear 3.4 bar. Is that psi or what?
I have 225/40/18 all around but front 18x8 rear 18x9
do I need to have different front and rear psi to make them balance??
Since the rear is a bit stretch.
Old 11-28-2012, 12:58 PM   #26
mkodama
mkodama's Avatar
My total toe is 0.2
Depends on whether your car has toe it or toe out. You want a small amount of toe in for stability.
Old 11-28-2012, 01:03 PM   #27
mkodama
mkodama's Avatar
no, bar is another unit for measuring pressure. I honestly figured in hong kong you'd be using bar or kpa since those are metric units of pressure.
really, you should be running around:
35psi = 2.41bar = 241kpa
Old 11-28-2012, 03:32 PM   #28
Grande D
My Ride: E36 M3
225 is a little too thin for a 9" wheel ideally speaking. It might be a slight issue but probably isn't causing the main issue.
Also, based on the picture of your car that I see, your car is lower than it should be for what is ideal handling geometry for the E46. There are long posts about this on M3forum.
Can you look up the part number tag of your steering rack? It will be on the steering rack itself. You may have the overboosted rack.
I think maybe it's a bunch of smaller issues adding up.
It will change your life!
Old 11-28-2012, 04:49 PM   #29
Steven747
My Ride: 05 330ci
im lowered with 225 on 9.5 and its super sticky so thats not why
Old 11-28-2012, 05:17 PM   #30
Grande D
My Ride: E36 M3
Uh huh. You have the optimal contact patch, and the best tire size for your wheel width. Where could I have gone wrong.
Old 11-28-2012, 06:10 PM   #31
Steven747
My Ride: 05 330ci
he has 19's and by looking at his sig it seems im about that height
Old 11-28-2012, 08:46 PM   #32
ajai
Big thanks!!! thanks for the calculation now I understand
But do I really need front and rear differednt psi? Or 35 all arou d is better
Old 11-28-2012, 08:48 PM   #33
ajai
Haha sorry forgot to mention. The picture is my old car. and it's photoshop drop.
u can find my car now in my other thread..
It's on 18 and it's not slammed
Old 11-28-2012, 08:49 PM   #34
ajai
I honestly forot the rack no, but it's in different oem model no from my memories. It's a Japan made BMW rack.
But it's oem
