Old 11-25-2012, 03:32 PM   #1
Alison
My Ride: 320d e46
Smile Door lock!!!
Hi i drive a 320d E46 the key has never worked by remote so have always used the key to lock and unlock. Yesterday i locked the car and heard something
fall down inside the door. I was locked out with no way of getting in. Had to pop a rear window to get in very messy.I have ordered a lock repair kit from e bay. Can someone explain how to remove the door lock without taking the door apart??
Alison is offline   Reply With Quote
Old 11-26-2012, 03:35 PM   #2
330iPilot
My Ride: Titanium Silver 330i
Impossible as far as I know. The DIY's I've seen look like its a bit of a beeotch to do.
http://forum.e46fanatics.com/showthread.php?t=600213
330iPilot is offline   Reply With Quote
Old 01-11-2013, 06:25 PM   #3
FFWD
My Ride: 99 323i, 01 M3 Cab
Hopefully you're fixed it by now, but if not, the 320d is a sedan, right? The link above is for a coupe. Sedan instructions are basically the same, but a bit easier to access the allen bolt:
http://www.bmwgm5.com/lock_cylinder.htm
Pay attention to step #2, or you will risk having the bolt fall inside the door, then you have no choice but to take everything apart.
By the way, when you said you had to pop a rear window, did you mean break the glass? I guess you won't like to hear that you could have opened the trunk with your key and crawled through the the fold down rear seats. That's what I had to do earlier this week (one of the most embarrassing things I've done in a long time - luckily I left work late, so it was dark and not too many people around).
FFWD is offline   Reply With Quote
