Australia
Old 11-26-2012, 01:48 AM   #1
selien
My Ride: 330CI
accessory power
Hi guys, I need to install a small device on my car (dash cam to be exact). I don't want it hooked up via the cigarette lighter so I bought a extra cable for it which allows it to be always on which detects knocks/movements.
Anyway... wondering, as I have 3 cables on this thing, red/black/yellow obviously being pos/neg/earth, I need to connect them to some other cables running through the car, just wondering which though? Has to always have power from the battery running through it when the cars not running.
Ta!
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 11-26-2012, 01:52 AM   #2
morningisbad
My Ride: E46 M3 Vert
You could patch right into the fusebox. I wired up an SSD in my glove box and patched right in. Probably the cleanest way to handle it ;-)
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 11-26-2012, 01:54 AM   #3
selien
My Ride: 330CI
Yea thats what I was planning but which cables should i tap into? theres a million and 1 there.
Old 11-26-2012, 02:01 AM   #4
morningisbad
http://forum.e46fanatics.com/showthread.php?t=956092
Similar to what I did. Should at least point you in the right direction.
-Karl Welzein
Old 11-26-2012, 02:03 AM   #5
selien
My Ride: 330CI
your a good man, thanks mate!
Sent from my GT-I9300 using Bimmer App
Old 11-26-2012, 02:48 AM   #6
selien
My Ride: 330CI
repost that link, that one goes to a titan trim set
Old 11-26-2012, 02:58 AM   #7
Pants.On.Fire
My Ride: 328ci
I'd go straight into the car stereo. Because I'm lazy. The Red Black and yellow will already be there assuming you have dynavin/aftermarket HU. If not, there should be a wiring diagram somewhere showing the different wires.
Pants.On.Fire is offline   Reply With Quote
Old 11-26-2012, 03:44 AM   #8
selien
My Ride: 330CI
all sorted, done it through the dynavin, thanks PoF!
Old 11-26-2012, 03:50 AM   #9
Pants.On.Fire
My Ride: 328ci
No worries, which dash-cam did you get?
For future reference, the yellow cable is a cable that goes to the battery, so constant power, not earth. The black is neg/earth.
Might pay to test the power being sucked from the yellow cable(the one that will make the dash-cam be on constantly. I just don't want you stranded with a flat battery. If the instructions say it's all good to go then I guess you should be sweet.
Old 11-26-2012, 04:40 AM   #10
selien
My Ride: 330CI
Yea I know black is earth, i just didnt write it up in order!
I bought the Itronics 100-HD, just being testing it, its actually pretty damn good, got it working in park mode also, still have to read up how much power it drains, but in the meantime, ill just unplug it when i park over night.
Old 11-26-2012, 07:11 AM   #11
morningisbad
Oops...stupid phone...
http://forum.e46fanatics.com/showthread.php?t=628416
-Karl Welzein
