#1 |
Reputable BMW shop - Baltimore MD area
Hey guys I have an E46 M3 and i'm having problems starting it. Think its the crank sensor because the battery has plenty of juice.
I'm new to the Baltimore MD area. Can someone reccomend a good BMW shop in the area? Thanks! |
#2 |
My personal experience. BMW dealerships from DC to Baltimore and everything in between (Im in Annapolis) are outright terrible. Find a good indy. Or learn to do it yourself.
If none of that is possible. Get the lube. Lots. Of lube. |
#3 |
My Ride: '06 330CiC, '03 M5
Stay away from the stealerships!!!
Could be fuel pump or cam sensor, crank sensors do not fail that often. Suggest you read the 2nd link below in my signature. Also suggest you Google BMW repair for your area, you will find a number of shops and reviews. There is even a mobile guy in your area that have had some decent reviews. Sarli Motorsports in Millersville, MD would be a suggestion. At Speed Motorsports is also an option, but maybe not close enough to you?
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 Last edited by jfoj; 11-26-2012 at 11:05 AM. |
#4 |
I got a guy that works on mine. Hes good and i def trust him. I will PM you info. He is right outside of Annapolis.
#5 |
Here is a post of shops from that region. I've only gone to The shop in NOva off of Rt. 1 near Crystal city called Alexadria Bavarian Service. The guy is good but charges the same labor as dealership
http://forum.e46fanatics.com/showthread.php?t=487465
_________________________________
my b u d d y ![]() |
#6 | |
My Ride: 2002 PY E46 M3
#7 |
My Ride: 2000 BMW 3XXi ZSP
@LM Racing welcome to the area, our BMW chapter uses several Indy shops in the area including one in your neighborhood. At Speed is in Hanover, MD there pretty good for the basics there's also Benchmark in Columbia and Behe in Beltsville which is the best Indy in the region. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA NCC Member Recognition Chairman NCC High Performance Driving School Registrar NCC Auto-X BOD Liaison DIY Senior Committee Coordinator 2006 E90 325Xi & 2000 E46 3XXi " Vision without resources is just hallucination" |
#8 |
Thanks everyone for your help. If it is the fuel pump do I have to use the BMW OEM? Or are there cheaper alternatives?
